Page 92 of 226 FirstFirst ... 42829091929394102142192 ... LastLast
Results 911 to 920 of 2252
Thread: Polo GTI High Oil Usage - Discussion Thread
  1. #911
    Apr 2011
    Sunshine Coast, QLD
    Quote Originally Posted by mchieff View Post
    They've just made the millionth 6r haven't they (1 Millionth Fifth Generation Polo now calls Down Under Home | VWWatercooled Australia).
    If so i don't think the forum problem % is representative of the overall user problem %
    One million Polos does not equal One million Polo GTIs.
  2. #912
    Oct 2010
    Melbourne, VIC
    Quote Originally Posted by RoknRob View Post
    Gambit, considering your presence on this forum, I'm surprised you're seeing the oil light. I would have thought you'd be checking more often. I remember my oil getting pretty low once, but no warning light. Your engine must be bone dry by the time you top up...
    Lulled into a false sense of security by the good engine in his original GTi
    Resident grumpy old fart
  3. #913
    Apr 2011
    Sunshine Coast, QLD
    Quote Originally Posted by kaanage View Post
    Makes sense...
    2011 Polo GTI | Black | 5 doors | Comfort pack | Audio pack | 9w7 Bluetooth | Xenons - a Return to VW!
    Previous ride: 2008 Mazda2 - ZOOM-ZOOM indeed!
    1st Ride: 1988 Red VW Fox Sedan!
  4. #914
    Aug 2012
    wgong
    Oil mark on my 2200km old gti is half way down the flat of the stick after the crosshatching. Taking to dealer today for top up. Car is 6 weeks old.
  5. #915
    Oct 2012
    NSW
    Quote Originally Posted by gavs View Post
    Mate, the twincharged 1.4 has oil consumption issues, regardless of the power output as does the 1.2 tsi (now becoming apparent in Europe) and also the 2.0TSI in the golf GTI. I don't think that power output can be used as an excuse for a design flaw.
    I just would have thought that it there was a design flaw responsible, then all engines would by definition have this flaw and therefore all would consume excessive amounts of oil, but I don't believe this is the case. I could understand if it might be quality control issues, but if some cars don't use any oil then it is more difficult for me to believe it inherent to the design. I have read numerous posts from people who own both the TSI and GTI models and they say they do not use oil.
    Incidentally, in the newspaper Carsguide today, someone wrote in about excessive oil consumption on their Audi Q5, but the reply was that using a litre of oil every 1,000 kms was normal - and that reply wasn't from VW, it was a general reply from Carsguide.
    MY13 Polo 77TSI manual transmission Comfortline in Candy White - "Herr Marco"
  6. #916
    Erskineville, NSW
    Quote Originally Posted by JonP01 View Post
    Just because they say it is so, doesn't mean that it's right.
    CarsGuide probably asked VWA for info. If I was in the business of road testing cars, I wouldn't want to get on the wrong side of an importer or manufacturer.
  7. #917
    Nov 2012
    South Africa
    Hi Guys,
    First post...
    I have seen that from Sept this year, CTH engine numbers are available on orders on the dealership system...
    Any CTH engine members here yet? Any issues?
  8. #918
    Jun 2008
    Ringwood, Victoria
    I understand what you are saying but a design flaw can be as simple as someone specifying too loose a tolerance so the people who don't have issues have the upper limits of that tolerance while the others are at the bottom limit. Yes, higher compression and forced induction highlight these issues even more but that is frankly no excuse. You do not hear of these kinds of issues from other marques that use the same philosophy like Renault or fiat....
  9. #919
    Gold Coast, QLD
    I've been out of the loop for a while, so forgive me if this has been answered - what exactly does changing the pipe do? I haven't been able to find a clear response after searching.
    Reason I ask, is that after a period of low oil consumption in my car, the problem recurred. Last month, I took the car back to the dealer and they changed a vent hose. I haven't driven enough to tell if it has made a difference yet, but wonder how exactly it is supposed to work... the young man at the desk couldn't tell me.
    Cheers.
  10. #920
    Jun 2008
    Ringwood, Victoria
    Nobody really knows, there *might* be a valve change in the hose but I am personally very dubious about it. If the issue is blow by, the better solution would be to fit a separate catch can.
