Results 1 to 10 of 2252
Thread: Polo GTI High Oil Usage - Discussion Thread
    Jun 2008
    Ringwood, Victoria
    Karly, don't forget that the dipstick only shows ~1L of the entire oil volume in the engine and if you have been driving differently, ala more city stop-start driving vs freeway or more mountainous driving vs flat, these can all effect oil usage.
    I hope that they do the breather fix for you and your consumption stabilises...
    Jan 2009
    I wonder if everyone is following the proper procedure when checking the oil level...
    It can be surprisingly easy to misread the level and inadvertently overfill.
    Adelaide hills, SA
    For those that didn't think about it.
    The oil level should be checked with the engine at operating temperature, standing on the leveled ground, 5-10 minutes after you've switched the engine off. Put only small amounts of oil in and recheck it, as Diesel_vert says, it's easy to overfill.
    Sep 2012
    NSW
    Update: Took the Polo into mascot VW, they took car did 1L top up and gave me a free 1L bottle to take with me. All done within 10 minutes. Awesome service.
    Aug 2012
    NZ
    Does anyone know approximately how much oil will need to be added if the oil lamp comes on (for a Polo GTI 1.4 TSI engine). I will follow the correct procedure, add a little then check etc. But it would be good to know an approximate amount to add. Also how many litres of oil does the engine take? 4 litres?
    May 2011
    Quote Originally Posted by Zepelin View Post
    1 Litre when the light comes on - but when refilling, don't just put a full litre in at once - do it bit by bit and keep testing the level.
    The engine takes around 4l
    Polo GTI - 5 door - Candy White, Xenons, Comfort Package, Audio Upgrade, Bluetooth, Parking Sensors and Tint
    Sep 2011
    VIC
    Another oil consumption test started for me today but they have ordered the new hose regardless, I can't fault the service I have got from the dealership really but how many times to fix the same issue??? I always check on level ground, at operating temperature and add bit by bit. My driving hasn't changed at all but I'm wondering whether I just hit that point in kms which also happened with the previous engine.
    Also getting a new clutch...
    Oct 2012
    NSW
    Quote Originally Posted by Zakarados View Post
    I am curious - what exact oil did they give you? I went to buy a litre of the Castrol Edge Professional 5w30 a couple of weeks ago but the dealer did not stock it. They had their own VW branded Longlife oil in 1 litre containers in stock and I was told it was all the same oil. Just wondering if it really is and Castrol just package it up for VW and Audi.
    MY13 Polo 77TSI manual transmission Comfortline in Candy White - "Herr Marco"
    Sep 2012
    NSW
    Quote Originally Posted by JonP01 View Post
    It is the VW branded bottle. I will have a look tomorrow to see if it states anything about Castrol.
    Oct 2012
    NSW
    Thanks. It's OK - no need to look - I looked mine over sitting on the dunny and never saw any mention of Castrol.
