Sad to say but after only 2000km my engine oil light is on. So i read through the post and please correct me if I'm wrong but when I go to the dealer I should ask for
1. the new hose part?
2. top up the oil ( if the light comes back on too quickly then try using Liqui Moly Top Tech 4200)?
Real possibility it wasn't full from the dealer though mate...
Ok took mine for a nice little fang on Saturday and probably consequently now need an oil top up! Took 500ml in approx 3,500km so I'm crossing my fingers it stays at that current usage which is not too bad and well within the guidelines in the manual.
Curiously, what type of engine oil the VW dealerships are using over there? Is it a 5W30 504/507 VW Spec?
504/507 is a higher grade of engine oil due to the better basestock oil used and higher HTHS(High Temperature High Shear) specs.
If I am not wrong it has a lower oil lose rate than a regular synthetic oil.
