Page 70 of 226 FirstFirst ... 2060686970717280120170 ... LastLast
Results 691 to 700 of 2252
Thread: Polo GTI High Oil Usage - Discussion Thread
  1. #691
    Italy, Piemonte
    Quote Originally Posted by kevinctr View Post
    4. Even though the GTI has a power assisted oil circulation system to cool the turbo bearing down when engine is shut off, try to idle the car for 1min before shutting it down.
    I agree almost on everything you say about break in period and usual way to drive the GTI (furthermore your suggestions can be applied to every kind of engine). This way could help to reduce oil consumption, but I don't think is the major cause or a solution...
    BTW, the GTI has a power assisted WATER circulation when engine is shutted of (15minutes)...
    Max
  2. #692
    Portugal
    I also think if it was a question of the running in method VW would put those suggestions in the manual to save their bacon and not be looking for solutions for it...it is pure and simple design flaw. I imagine that when they were giving out awards to this engine all of the design team wanted to be on stage to be recognised but as soon as they started to look for a culprit regarding the oil issues all of a sudden everybody was on sick leave
  3. #693
    Singapore
    Quote Originally Posted by kawabanga View Post
    Max
    Thanks for pointing the error out. Thats why proper cooling down is still necessary on the VW. I used to drive Honda only and I seen a video of Honda Reving every Vtec engines at redline for few mins after its transfered into the car. Its simply to make sure everything is running well and to break in the pistons rings. Maybe VW dont do this step?
  4. #694
    Apr 2012
    Queensland
    G'day Dav - wrote a letter to VW - something fishy - not confirming anything about this so called 'PART' to fix the problem. All they tell me they are aware of it.
    I am waiting for my 1st service - if not resolved there will be lawyer letters following....
  5. #695
    Italy, Piemonte
    What do you think of those pics?
    This is a faulty engine with 15.000Km and more than 1 liter per 1.000Km...
    POLOVW.IT • Leggi argomento - GTI - Consumo d'olio
    Cylinders seem to be ok, head is not so encrousted...
    I can't say about piston, brown is for sure exhaust side, but doesn't seem so bad below rings...
    Someone can say if oil consumption for this engine could come from upper side (intake - oil separator) or from lower side (inappropriate piston ring's sealing)??
  6. #696
    Singapore
    In my own experience it seems the piston rings are not sealing to the cylinders but I wonder if its all 4 pistons or just 1
  7. #697
    Jul 2012
    Mars
    Quote Originally Posted by cyborgcuprajq View Post
    I'll check my new engine CODE when I get my car back...
    So? Would you please tell us what is the code
  8. #698
    Italy, Piemonte
    In Italy they are still installing the old CAVE engines...
  9. #699
    Jul 2012
    Mars
    Oke, thanks!
  10. #700
    Mine's: 03C-100-040-AX
