My dealer told me that Volkswagen doesn't make anymore brand new engines. They just repair the defective ones which were taken from someone elses car, change the defective part and put a new number. I know this because they fitted a repaired engine into my car and it had low compression in all cylinders (and it was made[Overhauled] in April 2012).
I'm getting a new engine in the week of the 18th.
Will be taking the matters to Consumer Affairs if it's not a new engine and not fixed
2010 Polo GTI - 5dr Flash Red
Completed upgrades: RNS 510 install, Retrofit MDI, Bluetooth
Planned upgrades: Amp, 3 way speaker install
Planned mods: APR tune, Brembo brake upgrade
Should start talking to them now karly...Give yourself plenty of time to learn and understand the rules. VW will try and beat you in the law game quite quickly.
Any advice? Sounds like Karly and I are in the same boat
Shocking that a "new" engine doesn't fix the problem!
Resident grumpy old fart
Sorry but im pretty damn sure that's illegal here in Australia. They take an engine, rebuild it badly then give it a new engine number when that number is already in the system and assigned to a VIN? That's called re-birthing mate. Now, what I know that they do do in new-motor cases is they will get a bare motor (just bottom end, valve train and head) then pull the ancillaries off your existing motor and bolt them to the new one. This is what happens elsewhere around the globe and due to Australia's re-birthing laws, I would be fairly certain that is what happens here. Umai Naa would be good to weigh in here, if he's floating around.
+1 for a new engine. I'd been getting the oil warning every 1200Km. At around the 7000Km mark did an oil consumption test and went through 940ml of oil. Booked to get it replaced in a few weeks. The surprising thing is they informed me that the acceptable amount of oil to be consumed for 1000km is 400ml.
For the record I took it very easy on the engine for the 1st 1000-1500km.
