Page 45 of 226 FirstFirst ... 3543444546475595145 ... LastLast
Results 441 to 450 of 2252
Thread: Polo GTI High Oil Usage - Discussion Thread
  1. #441
    Italy, Piemonte
    Quote Originally Posted by Hail22 View Post
    Recalling all the Polo GTIs on the market now would destroy the production line, they would need to stop production for re-designing of the vehicles engine bore, powertrain, turbo (whether it would be single or twin to replace the charger) even then the engine is built around having a charger on it.
    I think that when they will find a solution will be inserted in the production lines... This could mean a new engine or new piston rings, I don't know, but a recall for all the GTIs on the market using those new components should only be the right and minimal move from a serious brand like VW...
    ---------- Post added at 05:29 PM ---------- Previous post was at 05:26 PM ----------
    Quote Originally Posted by Diesel_vert View Post
    Sorry to say, but simply put, it makes more financial sense not to announce a recall and only fix the issue as they appear on a case-by-case basis.
    I agree, but they don't have to use time limits referred to warranty: if my GTI will show the problem in two years, at that time the warranty will be expired, what I have to do? Replace the engine with my money...? No, thanks...
  2. #442
    Quote Originally Posted by kawabanga View Post
    I
    But, the problem, if it exists, is there from new. It doesn't just appear 3 yrs later.
    If the problem is reported DURING the warranty period then the manufacturer is obliged to fix it even after the warranty period.
  3. #443
    Italy, Piemonte
    Quote Originally Posted by pologti18t View Post
    In Italy we have a lot of cases (GTI, Ibiza and Fabia) where the problem came up after 10.000 or 15.000 Kms, till then the oil consumption was absolutely ok, that's why I'm so concerned...
  4. #444
    Jan 2011
    I'm off for an oil consumption test on my May 2011 Build GTI. Ive done 6000kms and used over 3 litres of oil.Not happy. My old Mazda SP23 didn't use 3 litres in 60,000km's!
    Polo GTI 5dr Candy White
  5. #445
    Dad's polo had an oil consumption test and it had used 750ml in 1000kms. Further investigation by Volkswagen determined that position rings need replacing so out comes the motor!
  6. #446
    Potts Point, New South Wales
    Basically getting oil past the piston rings. To be fair though.....The car would either be blowing black smoke or white smoke if it was burning that much oil.
  7. #447
    Well this is what Volkswagen have determined after having the car for a day and doing their own tests so I'll back them in. Pretty sure they would have done anything to avoid changing the rings if they weren't sure.
  8. #448
    Jan 2011
    Hi all
    I have been told by the service manager that they wont do an oil consumption test before 10000kms.
    Any thoughts on the reply he gave me below.........
    "Volkswagen advise that the engine is still running in until approx 10000kms and some oil consumption, given the grade of oil used in the engine in the factory, is not unusual and to be expected. If oil consumption of greater than .5 ltr per 1000 kms is experienced post 10000kms an oil consumption test can be conducted. We could start an oil consumption test (drain and refill the engine oil) however this would obviously drain the factory engine oil which is not recommended."
    Any advice from those who have had similar experiences would be appreciated.
  9. #449
    Jun 2008
    Ringwood, Victoria
    Official line from VW was that the running in period where the engine is expected to burn more oil than normal is the first 5000kms.
    And by "drain and refill engine" he is refering to the oil that has probably been used to top up because if you have been topping up enough to need a consumption test, fair chance there's not much of the original, factory oil left....
    I would call into another dealership and get their thoughts on the matter.
  10. #450
    Sep 2011
    VIC
    Quote Originally Posted by nugget1312 View Post
    Hi all
    I can tell you that mine was started at 8,000km and it was going through heaps of oil, and at the rate you have quoted I doubt you have much factory oil left so I would request one to be done sooner. At that rate I can't see it suddenly becoming better now its at 6,000km.
