2011 VW Polo 77TSI | Manual | Savannah Yellow | Comfort Pack | Sports Pack |
Installed: Whiteline Rear Sway Bar, H&R Springs, Resonator Delete
That's the easiest way, yeah
Dieselvert, I just find it daft that VW are making people panic due the level dropping on their dipstick, so when it drops by half the dipstick level over, say, 2000kms, then people panic and think "oh crap, my car has a capacity of 4 litres and half of it is gone in 2000kms!". The sump has a mighty big sensor on it which lets you know when the oil level realistically gets low, so why not have a true-er reading on the dipstick, it just seems logical to me and if indeed it is that critical to re-fill after losing 1L of oil, then it seems like VW engine engineers are putting owners at quite a level of risk.....
Just my opinion of course
If you lose 1L of oil, then you DO need to top it up. So the dipstick and sensor are doing their job etc. I'm not sure how the dipstick being at the bottom and people having to add in 1L was then interpreted as the car being empty and having used 4L....
I've never owned a car where the dipstick showed the total oil level rather than than just the top litre and a bit that indicates top up is necessary and on every car I've owned the Min to Max level has been approx 1 litre so it's not only VW that does this. As for putting owners at a level of risk, I would have thought that a dipstick that indicates top up is necessary well before the engine ran out of oil would be much less risk than one that led the owner to beleive they were safe because the engine has "some" oil in it.
George
06 Jetta 2.0TFSI Killed by a Lexus!
09 Eos 2.0TSI DSG Loved this car but has now gone to a new home!!
14 EOS 2.0 TSI has arrived!
Due to various technical reasons related to the way they function, it's critical that the engine actually has enough volume of lubricant for it to be of any use.
The MIN level on the dipstick refers to the minimum amount of lubricant the engine can function properly on. Going below this level means you risk serious engine damage.
There is no point of the dipstick to represent absolute volumes (i.e. max. = 5 L, min = 0 L), as the engine would almost certainty be permanently damaged just at the halfway mark. If you continued on and let it drop even further, it won't be long before the engine will seize up. Thus, it would serve no useful function (apart from generating business for engine rebuilders).
Exactly. Most of the oil drains back to the sump when the engine stops so the oil level you measure is far higher than the level when the engine is running. And to allow for surge when cornering, accelerating or braking, the amount of oil must be greater than the amount needed to fill the oil galleries else oil pressure will drop in these circumstances with the obvious outcome to the most heavily loaded surfaces.
If the oil level fell below the mininum on the dipstick, I'd be worried that the engine may have suffered some damage already.
After 3,500km, I decided I better check the level. To my surprise, only 0.5 litres. Maybe I'm lucky or the high revs when new has something to do with it.
2011 Polo GTI 5DR - Candy with Comfort Pack, RNS510 and 9W7"Beggers are not Choosers"
I would like to add that the drop in oil does NOT seem to be a linear process... at least in my car.
I've been lulled into a false sense of security for the first 1500kms after a top up, where the dipstick level stays at or near full. Then, the level seems to drop quite rapidly in the next 500km.
I think I've posted here twice about how my oil consumption issues seem to have resolved, only to correct myself soon after.
My 2 cents.
2011 Polo GTI | Black | 5 doors | Comfort pack | Audio pack | 9w7 Bluetooth | Xenons - a Return to VW!
Previous ride: 2008 Mazda2 - ZOOM-ZOOM indeed!
1st Ride: 1988 Red VW Fox Sedan!
