Page 12 of 226 FirstFirst ... 210111213142262112 ... LastLast
Results 111 to 120 of 2252
Thread: Polo GTI High Oil Usage - Discussion Thread
  1. #111
    Jun 2008
    Ringwood, Victoria
    Well, 7000 pistons only equates to 1740 engines which I guess is still a rather high number. To clarify:
    Out of approx 25-30 GTI owners:
    3 engines ALREADY replaced
    4 undergoing official consumption tests
    1 booked in for new rings / possible rebuild
    2 already with new rings, one of which is back on official oil consumtion test.
    So, based on that, out of a very small smaple size there are already 10% failures with the potential of that becoming 20% rather quickly. Being based in an automotive background (like I also am) you would know that a reject rate higher than 1-2% is deemed unacceptable, especially for a company operating under ISO 900 and ISO14001 standards for quality systems and environmental management systems.
    Some of these GTI's are running like 2 strokes with the amount of oil they consume. I'd like to know what the EPA would think about the amount of harmfull emmisions coming out of the exhaust pipes of these cars!
    I'm currently a lucky GTI owner and I put it down to the running in period I gave the car, some others aren't so lucky..... Guy's is a definate exception, but I believe that his too is due to the running in (aka flogging) it got from day 1 and it looks to have helped
    Guy, by the way, what oil do you run in the Polo?
  2. #112
    Castrol Edge, 5-40, only use it because its convenient.
    Audi seem to have a bigger problem with their 2.0 TSI's (Valve lift), we have some threads going on at OZAudi, and there are a lot of people having issues, and I'm sure a lot less cars delivered.
    Q5 2.0 TFSI Burning Oil Problems
    A4 / A5 / Q5 Q5 2.0 TFSI Burning Oil Problems
  3. #113
    AutoBahn
    Do you think a product campaign will be coming out considering from what Gavs said 10% is quite a large figure and to my knowledge i believe in the UK with the 1.6 TSI "Explosive motors" was only 8% (correct me if i am wrong).
  4. #114
    Jun 2007
    Quote Originally Posted by gavs View Post
    Per day........line was running 7 days per week a that time.......that's some 12,000 engines in a week........the point I was making is that the numbers are very high compared to the number of failures being talked about.
    To clarify:
    I'm not saying there is not an issue, all I'm saying is that conclusions are being drawn from incomplete data. To arrive at the conclusion there is a 10% failure rate overlooks a very important issue, that being that only a small group of (rightfully) unhappy owners expressing their opinion on an internet forum.....unhappy consumers vent their spleen......the majority of happy owners don't get online to say how good their car is. The sample group is way too small.
    06 Jetta 2.0TFSI Killed by a Lexus!
    09 Eos 2.0TSI DSG Loved this car but has now gone to a new home!!
    14 EOS 2.0 TSI has arrived!
  5. #115
    Jun 2008
    Ringwood, Victoria
    Where abouts do you get it from, I've been looking high and low locally and cannot find anyone who sells it, I can only find the Edge Sport which isn't to the VW engine specs, Castrol edge is specifically for VW and Audi, yet it's not sold here, brilliant!
  6. #116
    Mar 2011
    Found it at supercheap
    Castrol Edge Sport Engine Oil - 5W-30, 5 Litre - Supercheap Auto Australia
  7. #117
    We get ours from Burson Auto Parts or Repco!
  8. #118
    Jun 2008
    Ringwood, Victoria
    Quote Originally Posted by ATYPIC View Post
    It's different oil. For anyone else reading this Castrol Edge SPORT does not meet VW engine oil requirement specs 504 or 507 and if indeed you do put this oil in your engine and you have oil related engine issues, vw will void your warranty. Would they go to the trouble of testing the chemical composition of the oil? I don't know, but would anyone like to risk it.......?
    The reccomended oil is Castrol Edge, here is a picture of the bottle:
    This is the product that supercheap sell which is Edge SPORT:
    Guy, I'll have to double check, see if they do sell the proper stuff now.....
  9. #119
    Jan 2009
    Castrol sell and market different lubricants according to region;
    - Castrol Edge 5W-30 (504.00/507.00) only appears to be distributed and sold in the E.U.
    - Castrol Edge Sport 5W-30 (502.00/505.00) is distributed and sold in Australia, and probably the rest of Oceania as well.
    Regarding VW oil standards, here you can actually use either;
    - 502.00 : because Australian delivered cars are not on the LongLife service regime (variable intervals), or;
    - 504.00 : because 504.00 spec supersedes the older 502.00 spec.
    Naturally, given the choice I'd recommend using the newer 504.00 oils, as they were specifically designed for FSI/TSI/TDI engines.
    Also note, that you don't have to use Castrol exclusively - you can use any brand of lubricant as long as it has been formally approved by VAG.
    It would appear that Audi have acknowledged the problem by releasing a fix for excessive oil consumption (at least for the 2.0 TFSI):
    A4 / A5 / Q5 Q5 2.0 TFSI Burning Oil Problems - Page 4
    I wonder if a fix for other engines will now be forthcoming from VW...
  10. #120
    Feb 2009
    Sydney, Australia
    As per the Fuels and Lubricants forum, there is a VW, Skoda, Audi Factory Approved Oils & Other Lubricants thread. It contains lists of the currently approved oils. And there are lots of them.
    A word of caution, as Diesel_vert has pointed out, some oil is marketted with different names or specs in different regions, so you should always check the label of the local bottle to ensure it has the VAG 504.00/507.00 certification.
    I and several others for instance use Liqui-Moly TOP TEC 4200 | 5W-30 (scroll down that page to it) which is both Germany made and engineered. It's around $80 for 5L from several places such as Autobarn, MotorActive, and even some of the VAG specialists, such as European Autotech.
    Anyway... check the other sub forum, and see what others have been purchasing recently
