Page 9 of 226 FirstFirst ... 78910111959109 ... LastLast
Results 81 to 90 of 2252
Thread: Polo GTI High Oil Usage - Discussion Thread
  1. #81
    Melbourne's East side
    Quote Originally Posted by ATYPIC View Post
    To find the oil temp just scroll through the MFD menu via the up/down control pads on the right hand side of the steering. I'm sure this would be the same as the Golf.
    Quote Originally Posted by Eaglehawk View Post
    Yes, there is an MFD reading for the Oil Temperature. Check your settings to see if it's been "enabled" for display. It should be the display one "down" from the speed display.
    Great, thanks guys.....sounds exactly the same as Golf then.All I need now is the Polo....oh and also some serious patience, good test for me for sure
    Current ride..MY10 Golf MkVI GTI | 5 dr | CW | < DSG >| Leather| Dynaudio | Sensors | Tint | R tails
    Current ride...MY12.5 Polo 6R GTI | 5 dr | CW | Xenons | Alcantara Leatherette /4
  2. #82
    Jun 2008
    Ringwood, Victoria
    Update:
    2000kms, usage is about 2.5mm above the hatched area on the dipstick so based on a 4.5 litre oil capacity, I'd say no more than 1 litter has been chewed up. Fingers crossed, looks like my run in method has removed the chance of a 2 stroke Gti....
  3. #83
    Apr 2011
    Low oil level warning has finally came on at 4800km.
    Topped up (300ml?) with VW stealer's oil. ($125 for 5L...I think)
  4. #84
    Adelaide hills, SA
    That's heavily overpriced, you can buy a 1L bottle of the Penrite Enviro+ 5W30 for $16 from Supercheap or Autobarn.
  5. #85
    Jan 2011
    Melbourne, VIC
    Only at 2300km and got the first oil light just the other day. Only had it two months, was a bit perplexing really! Was straight to the nearest dealership, who topped it up no questions asked. Said the initial oil used in GTIs is a thinner running-in oil, which usually burns up quickly.
    Glad to see it isn't an isolated problem...
  6. #86
    Feb 2009
    Sydney, Australia
    Yep, and you can buy Liqui-Moly Top-Tec 4200 5W30 for $80 or less too!
    They even have it at Autobarn these days too!
  7. #87
    Apr 2011
    Eastern suburbs, VIC
    Wouldn't you only need to have the running in oil in the car for like the first few 1000 k's if that?
    I was planning on changing my oil by 3000k's and then in between each service as well.
    2011 Polo GTI 5 door Candy White
    H&R Springs/APR Stage 1/OZ Racing Superturismo GT's
  8. #88
    Apr 2011
    Welcome to Canberra
  9. #89
    Jun 2009
    Based on my experience with high performance cars, I'll say that many of these engines do consume more oil than less performance oriented engines. Also, the same engine on different cars can be quite different even if both cars have been through the same run in procedures. Case in point, we had two high performance cars that use the same 6.2 litre V8. On the first one, we needed to top up oil every 2500km, whereas on the second one high oil consumption has never been an issue. Just don't ask me the science behind it.
  10. #90
    Jun 2011
    Finland
    I had to fill up (half a liter) of oil for the first time at 5600km. I guess 1l/10000km ain't too bad, but I hope the consumption will fall a bit.
