Originally Posted by
gavs
As a follow up, seeing as there is a severe lack of reading-of-owner's manuals that has afflicted 6R polo owners, the proceedure to check your oil is to ensure the engine has been operating at it's normal operating temperature (coolant at 90 degrees, oil 80-100 degrees), park the car on a level surface and wait a few minutes for the oil to drain back into the sump.After 3-5 mins, then check your dipstick. If you are checking it when it's cold, you will get an incorrect reading.
Just a query as I cant refer to either car nor manual.......
Is there a dedicated oil temp reading via the MFD like there is on the Golf GTi? If not, how do you know when it's up to normal temp.....just asking cause I tend to look at my oil temp often on my Golf and it tends to take a bit longer to reach normal temp than the coolant does
Current ride..MY10 Golf MkVI GTI | 5 dr | CW | < DSG >| Leather| Dynaudio | Sensors | Tint | R tails
Current ride...MY12.5 Polo 6R GTI | 5 dr | CW | Xenons | Alcantara Leatherette /4
