Page 200 of 226 FirstFirst ... 100150190198199200201202210 ... LastLast
Results 1,991 to 2,000 of 2252
Thread: Polo GTI High Oil Usage - Discussion Thread
  1. #1991
    Erskineville, NSW
    same amount of oil but a more focussed pattern?
  2. #1992
    Aug 2009
    Sydney,NSW
    I use to get up to 103-4 degree for oil temp when on freeway.after the oil jet replaced,i hv 92 steady. Not sure is direct related or not
    2013 POLO GTI Black
    2005 MKV 2.0 FSI Black
  3. #1993
    Oct 2013
    Frenchs Forest + Terry Hills, NSW
    I've just done 1000km & I've been back to the dealership. Apparently it's now 200ml/1000km.
    I'm not sure it that's even accurate, cause they did the "check up" in like 5mins... probably just enough time to check the dipstick...lol
    But by my visual observation -
    - dipstick is showing little to no use of oil
    - less visible black spot on the back, they're tiny tiny black spots now that's only visible when I run my fingers across the hatch.
  4. #1994
    May 2013
    keilor
    700ks oil level has not moved, still keeping fingers crossed though
  5. #1995
    Aug 2009
    Sydney,NSW
    850km done,dip stick still full
    2013 POLO GTI Black
  6. #1996
    Jun 2008
    Ringwood, Victoria
    Quote Originally Posted by RoknRob View Post
    Ha, ha! Oil starvation!
    But seriously, can anyone comment: if keeping the pistons cool with oil is a good idea, can reducing the amount of cooling, by reducing the oil squirted, could that maybe be less healthy for the engine? I would consider putting up with the oil consumption, and NOT changing the oil squirters, if that was the case. But I ain't no expert. Would love someone knowledgeable to comment. Cheers.
    Sent from my Nexus 7 using Tapatalk
    It really depends on if they are always squirting in every piston stroke or if they are ecu controlled dependent on coolant, intake, oil, exhaust temps etc... If the squirrels are atomizing oil into vapour inside a poorly sealed engine then I can see how this could contribute to oil consumption but on a properly put-together motor, there shouldn't be an issue. In 72000kms I have put in a total of 1ltr shell helix ultra extra, 2.5ltr of Liqui-Moly top tech 4200 and 1ltr Fuchs Titan. As I have always said, it comes down to manufacturing tolerances. I've been lucky in that respect but had a fair cop of DSG crap!
  7. #1997
    Jul 2012
    Sinagra, Western Australia
    From the quick look I have had at the squirters, the new ones appear to have a bigger bore.
  8. #1998
    May 2013
    Qld
    Quote Originally Posted by POW View Post
    Ours sits at 89-92ish. Last topup near 3 thousand kays ago, im down the to the round ball on the dipstick...
    Nice tik tik sounding engine...
    I think a trip due to dealer again.
  9. #1999
    Aug 2009
    Sydney,NSW
    What tik tik sound? Gear box?
    2013 POLO GTI Black
  10. #2000
    May 2013
    Qld
    Tappets?
    Definately notice change in idle noises everytime it goes low
