Page 193 of 226 FirstFirst ... 93143183191192193194195203 ... LastLast
Results 1,921 to 1,930 of 2252
Thread: Polo GTI High Oil Usage - Discussion Thread
  1. #1921
    May 2014
    Mornington Peninsula, VIC
    Fair call gavs
  2. #1922
    Feb 2014
    My late 2013 built MY14 Polo GTI is currently undergoing an oil consumption test. Has chewed through ~4L of oil in the last 4000kms. Currently, the car has done 7,300km.
  3. #1923
    May 2013
    Qld
    Quote Originally Posted by VW Convert View Post
    This may work for your particular car but I don't think it reasonable to assume that this is the case for all 1.4 twinchargers burning oil. Having followed this thread since its inception, it's clear to me that VW have tried all sorts of ways to fix the issue, in many cases it appears unsuccesfully. There is much more to this issue than the way the car is driven.
    George
    Agreed, the missus is hardly a hoon and does 99.9% of the driving and boy does it burn.
    I drove it while she was FIFO and it used very little.
    I always drive in manual and shift around 2700-3000 rpm and with the oil temperature shown.
    Only case ive seen no oil being burnt was on briskoda where some chap in italy used some custom pistons and vola.
  4. #1924
    Aug 2012
    sydney, NSW
    Went through the forum and if I am correct according to Gav's display picture to reach mark C that would mean the car went through about 2L of oil and at that point that is when the engine oil light appears??
  5. #1925
    Aug 2012
    sydney, NSW
    if anyone wants anything done about their oil consumption after your dealership keeps on telling you BS directly write to Volkswagon Australia and the matter will be better sorted.
  6. #1926
    So apparently VW/Skoda are installing new/revised oil squirters onto the 1.4 twincharge engines to try and reduce oil consmption issues. My bro who works for Skoda told me this a few weeks ago (after me asking him how many Fabia vRS's have come back with oil/DSG issues).
    I haven't seen any mention of these oil squirters on here - anyone had this done yet? These engines squirt oil onto the bottom (or underneath) the pistons to cool them - i assume these are what have been revised.
  7. #1927
    Jun 2007
    I don't have specific knowledge regarding VW engines but in the truck and bus diesel engine world world that I've worked in for many years, oil squirtes are fitted below and squirt oil up inside the piston to aid in cooling the piston. Not sure if this applies to these engines though, first reference I've heard to this.
    George
    06 Jetta 2.0TFSI Killed by a Lexus!
    09 Eos 2.0TSI DSG Loved this car but has now gone to a new home!!
    14 EOS 2.0 TSI has arrived!
  8. #1928
    Jun 2008
    Ringwood, Victoria
    The point about them being fitted is accurate, I'd have to check the TPI's list to see if there is one regarding it yet... Makes sense though as another band aid solution...
  9. #1929
    Jun 2008
    Ringwood, Victoria
    Quote Originally Posted by k0e1 View Post
    No, bottom of the dipstick is approx 1 litre. Your oil light should definitely come on if you have burned 2 litres though, the engine only holds about 4.5 litres!
  10. #1930
    Aug 2012
    sydney, NSW
    Quote Originally Posted by gavs View Post
    thanks gav for the clear up so can safely assume light should come on within 1.5L or even exactly on 1L
