Page 4 of 226 FirstFirst ... 234561454104 ... LastLast
Results 31 to 40 of 2252
Thread: Polo GTI High Oil Usage - Discussion Thread
  1. #31
    Mar 2011
    Took the car in on Monday and the service guys have started a consumption test so I have to go back in 1000kms. But ill be back sooner than that because they STILL havent fixed my MDI.
    Me: "If your guys had of taken 5 seconds to check then they would have realised that its actually worse than before"
    Manager: "But we dont test it after we do the work"
    Me: "...what?!"
    3rd time is a charm hey?
    2010 Polo GTI 5dr, reflex metallic silver, MDI.
    Now Replaced With
    2012 Polo GTI 5dr, Candy White, Sunroof, Detroits
  2. #32
    Dec 2010
    Raised this question when taking delivery today. Was told high consumption is to be expected and that cars are delivered de-tuned and that over time consumption will reduce and engine will loosen up. Was also told although not mandatory, recommend an oil change out at 6 months.
    Don't know what to make of all this
    2011 Polo GTI - I have it, I Love It!!!!
    Candy White 5 Door, Comfort Pack, Audio Pack - RCD 510, Bi-Xenons, Panoramic Sunroof
  3. #33
    Mar 2011
    I agree that you should expect it to be high at first but ive done 3600kms and ive had to tip 3 litres into the thing. Im gonna start keeping reciepts
    Now Replaced With
  4. #34
    Dec 2010
    Quote Originally Posted by Miles Away View Post
    Good thinking! I'd also recommend odometer readings at time of replenishment.
    For me, I'll be doing a monthly dip on the oil (engine cold). if oil needs topping I'll call the dealer service centre, consult and record conversation. bottom line is record everything you think is important about your car and collaborate it with another source that can be verified.
    Regardless of warranty stuff, if you take the time to do this it will help you - otherwise drive and enjoy
  5. #35
    Jun 2008
    Ringwood, Victoria
    Quote Originally Posted by Frostee View Post
    I'd take that as absolute bull***t mate, so theyre selling a car that doesnt meet what specs they advertise? Does the engine miraculously retune itself down the track? I'd say this is more dealer lies than anything else and just an excuse. If they truly recommend a 6 month top up, a) what if you do more than 6000kms in that time and b) why isn't it one of the scheduled services?
  6. #36
    Adelaide hills, SA
    Quote Originally Posted by gavs View Post
    Because there might be the time when they have to sell the car with scheduled servicing included and they don't want to over do it.
  7. #37
    Jan 2011
    I've used 800mls in 4500kms
    Polo GTI 6R - APR Stage 1
  8. #38
    Adelaide hills, SA
    Quote Originally Posted by bnescooter View Post
    That's normal and most likely, you will notice that you top up less and less oil for the same distance and when it settles that indicates that your engine is run in. Maybe time for the Stage2.
  9. #39
    Oct 2010
    Essendon, Victoria
    I completed a long run (600km) yesterday from the dealership in Mildura. Checked oil level this morning and it was just over 3/4 full. I will check it again at the end of the week and see if it needs topping up. I just bought some Liqui Moly oil (freaking expensive at $79.95) for the topping up. BTW, once the car was warmed up, I didn't baby it at all. Hopefully this method will reduce the oil loss.
    2011 POLO GTI 3dr, Candy White, Audio-Comfort-Xenon Packs
    MODS: H&R Sport Springs - Bilstein B12s - Whiteline Sway Bar - Milltek Cat Back Exhaust - Sparco Assetto Gara Wheels
  10. #40
    Jun 2008
    Ringwood, Victoria
    I'm very interested to see the results of your consumption after the drive back from mildura, did you continuously drive after picking the car up and keep the engine running? I wonder if the long running time might have helped you in the long run.... I believe the day I pick mine up will result in around 300kms of mountain break in
