the new squirter thing seems to made lots of people happy.
my car ran out of warranty last july - has anyone had it done out of warranty and is able to tell me how much it cost? ive read about 4 hours of labour.
edit: my motor is a my 13.5 CTHE
To quote someone else:
The technical bulletin/product information the dealer should be referring to is 2025520 which is currently in it's 9th revision to date(2025520/9).
>CAV 438345 - optimised hose for crankcase ventilation, 03c 103 474 ad;
>CTH 023901 - optimised air intake, 6r0 129 684 e;
>CTH 165646 - oil injectors with 1.2mm diameter, 03c 103 157 a;
Replace oil & filter;
Update engine control module software, latest revision being 03c 906 027 AR with 9970 version.
if you mean last month, I would be very nice to your dealer and see if they can do a goodwill claim.
It can be done in a day but is better to leave it with them overnight so the sealant can cure fully around the sump. Labour is as you say about 4hrs.
They can check and see if your engine falls in the build range for the bulletin.
sadly - june before last and no extended warranty. ill give them a call to see if its something they can do - i have spend a lot of money with them over the years
My previous 2013.5 Polo GTI CTHE developed same issue as yours at around 10,000 ks. I was not prepared to go through all the test b.s. with Solitaire because it was marginally within the 500ml/1000 spec. so I obtained a quote from them which I did not go through with. From memory it was around $1000 to $1200 but a while back now.
2015 Polo GTI with DA pack : Milltek Turbo back exhaust | DD spacer | JB1 | VWR Turbo Intake elbow and intake hose | BMC panel filter | KW Street Comfort coilovers | Whiteline adjust. endlinks | Harding DSG Perf. tune | Wagner Intercooler| Dotz Mugello 17 x 8 32ET
i did a test but i was within spec, just. so they weren't really interested in doing anything.
im a bit torn, theres a new model coming out and id expect that we would see it in about a year. do i try and keep my car going, cross my fingers that my dsg doesnt feck out and try and get another year out of it or do i go with a new 1.8 manual and be done with my current one.
regardless ill be taking one for a test drive this weekend which will probably end up with me taking one home![]()
did you get your new one through solitaire?
Loved my previous one but the oil consumption worried me so as soon as the new 1.8 came out I traded in my 6R in at Southern, I purchased the 1.8 prior to the release date but had to wait until the official day to drive it out the showroom.
Despite all the bad DSG hype I decided to stick with DSG and I don't regret it. Purchased the first one from Solitaire and I've been far from impressed with either dealer's service departments or rather service personnel/Manager attitude.
Good luck with your decision![]()
Hi Have a MY13 model GTI, been using 1 litre of oil per 1800kms or there abouts for the last 4 years. It would seem Castrol has done very well out of all this. I do wonder, with all the goings on with the emissions stuff, surely a car that chews this much oil would have rubbish emissions? I get it all up the back end of my car after a week. Or do they not take into account actual oil when its sprayed out the exhaust as far as emissions go?
