Page 216 of 226 FirstFirst ... 116166206214215216217218 ... LastLast
Results 2,151 to 2,160 of 2252
Thread: Polo GTI High Oil Usage - Discussion Thread
  1. #2151
    Apr 2011
    Sunshine Coast, QLD
    Quote Originally Posted by Looppty View Post
    Damn, this is so upsetting. I knew I should've bought a Golf Gti despite the $10- $12k price gap for the same KM.
    My 118 Golf gave me the impression of reliability, that's why I went for the polo Gti, didn't expect this problem ��
    Or, you could think of it this way. Assume $75 per 5 litres of VW approved oil, or $15 per litre. Assume you top up with 1 litre every 2000km. If my calculations are correct, you will need to drive 1300000 km in your Polo to break even with the extra $10000 you would have spent on your Golf GTI.
    Are you planning on keeping your Polo for over 1 million km? If not, you'll be finishing ahead, despite the extra oil usage. . Feel better now?
    Sent from my Nexus 7 using Tapatalk
    2011 Polo GTI | Black | 5 doors | Comfort pack | Audio pack | 9w7 Bluetooth | Xenons - a Return to VW!
    Previous ride: 2008 Mazda2 - ZOOM-ZOOM indeed!
    1st Ride: 1988 Red VW Fox Sedan!
  2. #2152
    Apr 2011
    Sunshine Coast, QLD
    Quote Originally Posted by gavs View Post
    What to do to fix it? Well, first off i'd stop driving in D because it puts too much pressure into the combustion chambers and keeps the revs too low, plus with dodgy oil dribblers and not squirters, this isn't going to help either. Second option is get a DSG tune, this can do wonders for the oil consumption but not fix it and 3rd is to look at an ECu tune which changes the way the engine thinks, I've said it dozens of times, the software in these cars from the factory is just plain dumb....
    The intent of the factory software, I believe, is to maximise fuel efficiency. I think it's important to mention that the trade off for each of these solutions is reduced fuel efficiency. So you may spend less in oil replacement, but more in fuel. There may be other benefits to the engine long term in reducing the oil consumption however.
  3. #2153
    Mine is in for the "do 621 miles and come back" test now. Seeing as I sometimes only do 50 miles in a week its going to be a while! lol.
    When I spoke to the guy at the dealer he said that they had only ever replaced 1 engine and that another was down to the injectors leaking?
    Any thoughts?
  4. #2154
    Mar 2013
    I have a Fabia vrs 12 plate, early CTH engine that would use up to 700ml per 1000kms. Most of my driving is 11km drive to and from work with other thrown in. Mostly driven in D. It would use just as much oil whether in D or flappy paddled along. A 600km blast up the highway would show much less oil consumption. I had the oil jets and software updates done under warranty and I have since done 4000kms and just the other day, put 150ml oil in just because I am pedantic. Most of that driving again was done in D only. Awesome result I think!!
  5. #2155
    Sep 2012
    Perth
    If you're doing the test, drive it as normal*. Don't go and do a long drive to get the test over with, because they tend to use less oil on long runs. I've had a similar experience to Alloyvee - from 200-500ml per 1000km to about 200-300ml per 5000km.
    * Or you could idle it for a long time if you want to fail the test.
    Now gone.... 2012 Skoda Fabia RS
  6. #2156
    Sep 2015
    Quote Originally Posted by RoknRob View Post
    Never thought of it that way, haha
    That's kinda comforting.
    And I always think that Golfs are ways overpriced because of its popularity.
  7. #2157
    May 2013
    i thought id gotten away with it and got one of the good engines as id make it to the service without needing to put really any oil in. until about 4 months ago that is. now ive hit the 38k kms mark and im starting to use 1L of oil every 2k kms.
    did these end up getting 5 year on the drive train in the end because of all the dsg woes?
  8. #2158
    Jun 2008
    Ringwood, Victoria
    Only on the DSG, not the motor and only if it was delivered within the marketing department's allocated time frame.
  9. #2159
    Quote Originally Posted by mrkris View Post
    Im wondering if you have something else going wrong if youve had a good drinker until now, it would be strange for the original fault (rings/clearance) to show itself after those miles, some other wear is possible to those components of course, but it could be a blocked breather or some other problem causing it, worth asking a mechanic to check it out for you tho.
    Bury S9 XL cradle for Touch Adaptor for sale: http://tinyurl.com/hgmjc4j
    Sold my Shadow Blue MY12.5 3 door Polo GTI for a WRX Hyperblue...
    SPOC - 1st Four.... www.DeskDivers.com & www.PloProf.com & www.2smoked.com & www.JonWallis.com
  10. #2160
    Mar 2007
    Hobart
    FWIW at ~50,000kms my Mk5 Golf GTI went from being a sipper of oil (~half a litre per 10,000) to 1 litre per 300kms within a couple of weeks. Clearly something failed, whether it be rings, cylinder lining I don't know. Nor it seems, did the dealer. Since the warranty repair with a new ring design the engine has gone back to sipping oil at its original low level. Hopefully it stays that way.
    2018 Golf GTI, Manual - gone.
    2017 Golf 110tsi Trendline, manual (gone - gladly)
    2007 Golf GTI, Manual, (gone - sadly)
    1978 Golf GLS; 1972 Superbug, (memories)
