Page 207 of 226 FirstFirst ... 107157197205206207208209217 ... LastLast
Results 2,061 to 2,070 of 2252
Thread: Polo GTI High Oil Usage - Discussion Thread
  1. #2061
    Aug 2009
    Sydney,NSW
    No,dont notice it.
    2013 POLO GTI Black
    2005 MKV 2.0 FSI Black
  2. #2062
    Dec 2014
    nsw
    Quote Originally Posted by k0e1 View Post
    Hi everyone after an engine replacement engine I'm still getting about 2000km before my oil light turns on. So I went back to the dealership asking about the new oil squiters. He told me that my 2012 polo GTI has the CAV engine and can not have the new oil squitter fix as it already contains that part in the first place, that the oil squitter fix is only for the CTH engine. Any truth in this?
    this does not sound correct to me either. Mongo's Fabia RS (with the same engine) is also a CAV and VW is wanting to change the squirters. That is not to say that this will be a good idea or that it will "fix" the problem (see Mongo's earlier comments at page 205). Also, noticed that those who had this done say that it just reduces the oil consumption sometimes and even then, it still continues to use a lot of oil. It seems more than obvious that after several years of this problem that VW have no clue as to what is wrong or how to really "fix" it. In the circumstances, people should really just lodge consumer claims with their local Tribunal in their State.
  3. #2063
    May 2014
    my car is MY13.5 gti with CTH engine, owned it since new, 21k kms on the clock at moment.
    It consumes as much as 500ml every 1000kms when my wife drives it at "D" mode and black soot came out all around the hatch in days.
    However it consumes less than 500ml every 5000kms when I drive it with manual shift only and I can barely the the black soot after 2 weeks before I took it to a wash.
    Very very strange behavior of this little car.
    As I am driving this car at most of time therefore I never took it to the dealership for oil test. Regular check ups and oil top up by myself is sufficient. Maybe I am just lucky.
  4. #2064
    Jul 2012
    Sinagra, Western Australia
    After doing oil squirters on over 5 cars now, never had one return with oil consumption issues. So I would think that VW have found the solution..
  5. #2065
    Aug 2012
    sydney, NSW
    Quote Originally Posted by Snail Style View Post
    Would you be able to tell me the part number to this squirter please. I called up VW rockdale and liverpool and they havent heard of this fix for the CAV engine
  6. #2066
    Jun 2014
    Wagga Wagga, NSW
    My dealer hadn't heard of the fix for my Fabia RS but after a little research they have agreed to change the squirters. Going to see them this week to book it in. Engine is the CAV by the way.
  7. #2067
    Sep 2012
    Perth
    This sounds like a promising development. Can anyone think of any possible problems that these modified oil squirters might cause? Sometimes these sorts of fixes cure the original issue, but cause other ones.
    Now gone.... 2012 Skoda Fabia RS
  8. #2068
    Aug 2012
    sydney, NSW
    Quote Originally Posted by danield View Post
    That good to hear that some dealers will actually help you out and change certain parts and not just you stupid excuses. If you dont mind after you get your new part in to tell me the part number that would be great. The dealership quoted me roughly $400 to get an oil squitter replacement but like every dealer they said this part isnt a new one. Dont want to be spending $400 and it aint the right one.
  9. #2069
    Jul 2012
    So...
    The technical bulletin/product information the dealer should be referring to is 2025520 which is currently in it's 9th revision to date(2025520/9).
    >CAV 438345 - optimised hose for crankcase ventilation, 03c 103 474 ad;
    >CTH 023901 - optimised air intake, 6r0 129 684 e;
    >CTH 165646 - oil injectors with 1.2mm diameter, 03c 103 157 a;
    Replace oil & filter;
    Update engine control module software, latest revision being 03c 906 027 AR with 9970 version.
    So basically if your getting around with a CAVE123456 equipped vehicle, you would need all three improved parts, etc.
  10. #2070
    Aug 2012
    sydney, NSW
    Thanks for the awesome information. I shall speak to my dealership and see what they say so althought the oil injectors has a CTH part number to it. It will still fit in a CAVE engine?
    So...
