Originally Posted by
RoknRob
Biz,
Thanks for your generous response.
At least one mystery is solved - that the light is not intended to light up at ignition - very surprisingly... Very "bizarre" !
So in the end, even if you could tell us where the light was, one would still need to have it checked to make sure it is functioning correctly... or just trust that it is...
As I mentioned, my oil was pretty low - down in the C level, according to the manual diagram - but no warning light came on. I guess for me, anyway, it is a trip to the dealer to have mine checked. I suspect they will understand my concern...
Thanks again, biz.
Q.E.D.
No need to go off on the "personal attack" road. But seeing as you have 'set the standard'..............I resent the cantankerous and non-sober remark. Mr Low and Weak. To resort to personal attacks, merely shows your inability to accept a written suggestion. You don't have to do anything. I am merely suggesting that you have invested $$$s into your car (with a value of warranty). Why not use the knowledge of the manufacturer? I hope the dealership are able to satisfy your enquiry.
In the end, you're going to do what I merely suggested. Hope the humble pie is to your satisfaction.
