Page 170 of 226 FirstFirst ... 70120160168169170171172180220 ... LastLast
Results 1,691 to 1,700 of 2252
Thread: Polo GTI High Oil Usage - Discussion Thread
  1. #1691
    Was driving directly behind a Fabia vRS this morning for about 10 mins on my way into town. Due to the oil consumption issues with these engines, i decided to watch the exhaust closely to see whether i could see any smoke. I didnt have to wait long - almost every time the car took off from a stand still, smoke puffed out the exhaust. Admittedly it appeared grey/black rather than blue, but not something you should be seeing from a new car.
    Have any of you guys ever asked a friend to drive your car while you follow behind and observe?
    I was behind a Tiguan TSI a while ago and noticed the exact same thing – smoke every time it took off from a standstill.
    Same thing with a friend's Brera 2.2, although that is an Alfa so it's expected
    Alex Aescht
    MY13 Dark Silver VW up! 5-door 55MPI manual — Comfort Style Pack, Comfort Drive Pack, Maps + More, Panoramic Sunroof
    MY11 Pepper Grey VW Polo Comfortline 66TDI manual ― Comfort Pack, Audio Pack.
  2. #1692
    Oct 2013
    Czech Republic
    Regular, I meant the oil recommended. The first oil is thin even more!
    Polo GTI 2013, 3 door, Candy White, VWR Exhaust, VWR panel air filter, VWR license plate holders, VWR sport springs, VWR sway-bar, red GTI badge at rear, RCD 510, AC, comfort pack, MFS, MTM shifting paddles.
  3. #1693
    Sep 2012
    Perth
    I've seen black puffs of smoke from Golf GTI's when the drivers give them some beans. Other turbo cars as well, come to that.
    Now gone.... 2012 Skoda Fabia RS
  4. #1694
    Apr 2011
    Sunshine Coast, QLD
    Quote Originally Posted by gavs View Post
    I checked mine yesterday again, I won't post what it was after 6500kms since the last oil change out of fear of upsetting some people....
    If you are referring to me, rest assured you are mistaken.
    I am actually happy for all of you without oil consumption issues...
    No, really!
    Grrrrrr....
    Sent from my Nexus 7 using Tapatalk 4
    2011 Polo GTI | Black | 5 doors | Comfort pack | Audio pack | 9w7 Bluetooth | Xenons - a Return to VW!
    Previous ride: 2008 Mazda2 - ZOOM-ZOOM indeed!
    1st Ride: 1988 Red VW Fox Sedan!
  5. #1695
    Singapore
    Quote Originally Posted by dening View Post
    I'm not sure? It's a few, they said it's the latest update of that tpi.
    Mine is MY12.5
    Sent from my GT-I9100 using Tapatalk
    Shd have a list of items replaced. Can you help check since its also a older CAVE model engine.
  6. #1696
    Jun 2008
    Ringwood, Victoria
    Quote Originally Posted by RoknRob View Post
    No, really!
    Grrrrrr....
    Nah mate, I was meaning more of a blanket statement for all those with consumption issues.
    After 6000kms of dedicated manual and sport only driving I saw a drop of 1.5mm on the dipstick.
    Lucas, I agree with your observation but if you follow any VAG turbo car, they all puff black smoke under decent throttle application. The GTI motor runs pretty rich down low but dangerously leans out in the top of the rev range so it's no surprise you're only seeing it puffing as the car takes off. Personally, I'd be very wary of running this motor to redline often without a tune. As usual though, VAG would rather keep replacing engines and components under warranty rather than admit they stuffed up.
  7. #1697
    Aug 2012
    wgong
    After a change to FUCHS at my 15k service have now completed 21k and has only needed 200ml top up.
    Still have soot on the back of the car but am happy that it is not using any oil.
  8. #1698
    Italy, Piemonte
    Hi there...!
    Probably you can find something similar also in Australia, here a car preparer (bobracing) is now able to modify DSG7 software: not only elimination of kick down, launch control, reduced shifting time, etc., but also D's behaviour, overall changing gear's revs.
    This will probably be useful for oil consumption problems for who still want to use automatic...
    I don't have it, but some guys are now testing this new modification: in the software programming phase you can choose at how many rpm it shift gear...
    Probably half way from the current D and S could be perfect...
  9. #1699
    Aug 2012
    sydney, NSW
    so after numerous oil consumption tests. VW maybe doing an engine rebuild for me. Just wondering what should I ask them to do in additon to just rebuilding the engine. Should I ask for new piston rings, etc??? Also would a rebuilt engine need to be run in like its a new car ? And finally does a rebuilt engine warrant the odometer to be reset to 0 ? or that only for new engines? Thanks guys will update you as well on how this case goes.
  10. #1700
    Jan 2009
    Quote Originally Posted by k0e1 View Post
    Unless you're prepared to pay for it yourself, the dealer isn't likely to do anything beyond what they've diagnosed is wrong, so you can request it, but isn't likely to happen as warranty.
    RE running it in, ask the dealership, but its something that opinions vary from baby it to drive it like you stole. I'm towards the later, don't flog it, but don't nurse it at low revs, engines are designed to rev so do that. I like the idea of putting it under load when new to bed everything in, so a nice mountain run which loads up the engine, also keeps the revs varying. I accept the logic in this approach.
    The odometer will not be reset.
    Good luck, hope it's all smiles once sorted.
    Daily: 2010 VW Jetta Highline
