Page 164 of 226 FirstFirst ... 64114154162163164165166174214 ... LastLast
Results 1,631 to 1,640 of 2252
Thread: Polo GTI High Oil Usage - Discussion Thread
  1. #1631
    Apr 2013
    Quote Originally Posted by Brent23 View Post
    hi guys...i'll be quick...my2013 polo gti...not sure if its is cave or cthe engine...oil light came on at 4800km...topped up myself(it was a sunday) with 500ml until it came on again at 5500km..had oil and filter changed by my mechanic(vw oil filter,castrol edge 5w-30) just passed 8000km oil light again,extremely low on dipstick
    took it to vw sutherland today,and there telling me i shouldnt have changed the oil until 15000km and that i have possibly voided my warranty!?!?!?! booked in for oil consuption test in 2 days...absoloutley furious!!! Thoughts guys? any help response much appreciated
    Sounds like they are trying to scare you and position themselves to get out of a an costly warranty job. There are two things I will point out. I was told by a specialist VW mechanic that VW use a oil with a special coloured dye in it so that they can tell if you used a different oil so ask them for a free bottle of oil. After owning my twincharger for 12k now and 3 consumption tests later I would recommend checking the oil every 500km yourself and then telling them that you will be in there the next morning for a top up via email and copy VW in for there records. As said before by others I would not recommend being aggressive with your dealer. Just go with the flow and keep on their backs. This will give you the best results.
    2012 Fabia II VRS Estate - APR stage 2 tune, Custom 2.5" turbo back full stainless exhaust with ceramic coated dump pipe, Harding Performance Cold air intake, Wagner Tuning Competition Intercooler, GFB DV+ diverter valve, Braille B2317RP battery, Eibach pro kit springs, Bilstein B8 shocks, Harding Performance F+R ARB, Super Pro bushes, Porsche 986 Boxster S front brake calipers, 330x28mm front rotors, Ferodo DS2500 front pads and Remsa rear pads, Enkei RPF1 17x8 et.35 with 235/40R17 Yokohama AD08R tyres, Maxton front splitter and Superskoda fender flares.
  2. #1632
    May 2013
    Qld
    Quote Originally Posted by mmmRacer View Post
    Some use castrol oils while some use valvoline
    Oil leaks maybe
  3. #1633
    Mar 2012
    Cronulla, NSW
    Took my GTI to Barloworld VW at Mascot to do an oil consumption test today.
    When I picked the car up they said it had been leaking oil from the hose and they replaced the following parts under warranty
    VW03C103474AD VENTHOSE
    VW6R0129684E PIPE
    VW03C103558AA VENTHOSE
    They also did the VW "Peace of Mind" check and everything came up fine.
    Hopefully this fixes my oil consumption issues??? For the first 27000km I never had a problem, but from there, I've been filling up a litre every 1500-2000km.
    Current Ride: Golf GTI Mk7 MY2014|DSG|Carbon Steel
    Previous Ride: Polo GTI MY2012|DSG|RNS510|Shadow Blue|Lenso GF7 18” rims
    Instagram: @lemonskin
  4. #1634
    Nov 2012
    clalyton,melbourne
    Quote Originally Posted by Nile View Post
    I definitely have the CAVE motor in my MY13, probably one of the last ones. Wish it was the CTHE in my car as that seems to be less prone to burning oil.
    Thanks for the advice too Zakarados. I suspect it may need an engine rebuild but will keep you all posted. Then of course I have the dilemma of whether to keep the car or get rid of it.
    same here.i have a MY13 and have a CAVE motor
  5. #1635
    Oct 2012
    Mine's MY13 with CAVE, had it replaced with another CAVE.
  6. #1636
    Dec 2012
    @Lemonskin, those are the parts from the crankcase ventilation mod TPI. Unless they actually found a split pipe to cause an oil leak I think they are using their smoke and mirrors trick again, most people are only getting marginal improvement from that TPI Mod.
  7. #1637
    Mar 2012
    Cronulla, NSW
    Quote Originally Posted by Yaks1974 View Post
    Hmmm yeah I did get that feeling but I'll give them the benefit of the doubt and see how it goes. A leak made sense seeing as I didn't have the problem for the first 27,000km but then have had to fill up 4 times in the next 6000km.
  8. #1638
    Aug 2013
    Quote Originally Posted by Lemonskin View Post
    Im having pretty much the same problem im doing part 1 of the oil consumption test. Denlo vw asked that i dont fill any oil until the 1000km has been reached pretty scared the oil is going to get pretty low but i guess i will have to wait and see
  9. #1639
    I was doing the same test and my oil light came on today at about 600kms! I went straight in. Do not drive it to 1000kms no matter what they say. If your light comes on before 1000 then you obviously have an oil consumption problem and they will just move you onto the hose swap, and then you do another consumption test...
    Interestingly I was topping up at about 1300, then 1600 (between fill up and light on) and yet during the consumption test it was 600.
    Parts are ordered for my car, I will be having them fitted next week and will report later on what happens...
    Bury S9 XL cradle for Touch Adaptor for sale: http://tinyurl.com/hgmjc4j
    Sold my Shadow Blue MY12.5 3 door Polo GTI for a WRX Hyperblue...
    SPOC - 1st Four.... www.DeskDivers.com & www.PloProf.com & www.2smoked.com & www.JonWallis.com
  10. #1640
    Mar 2012
    Cronulla, NSW
    Quote Originally Posted by GTI6R View Post
    Weird thing is I went in for the oil consumption test but they didn't even do it, just replaced those parts.
