Page 153 of 226 FirstFirst ... 53103143151152153154155163203 ... LastLast
Results 1,521 to 1,530 of 2252
Thread: Polo GTI High Oil Usage - Discussion Thread
  1. #1521
    Aug 2012
    sydney, NSW
    Quote Originally Posted by prcurrie View Post
    What type of driving do you do (city, highway, both) etc??
    Just city driving hardly any highway. and the back of the car is just filled with carbon dust, breather hose change didnt change it
  2. #1522
    Sep 2012
    NSW
    1500km after my engine rebuild and the oil has not moved on the dip stick. Highly recommend pushing dealers to do engine rebuilds if you are getting high levels of oil consumption. My MY12.5 Polo GTi was using approx 1L/1000km before the engine rebuild.
  3. #1523
    Sep 2012
    Perth
    Quote Originally Posted by Zakarados View Post
    Good to hear.
    Now gone.... 2012 Skoda Fabia RS
  4. #1524
    Jul 2012
    victoria park, WA
    Quote Originally Posted by kevinctr View Post
    I suggest you only top up your oil and check your oil with a cold engine before your first crank of the day. ITs the most accurate way to monitor oil lost.
    Thanks..but this still doesn't answer my question..i still have no idea how to measure my oil usage properly (I want to be able to measure it myself as I don't believe the dealer is doing it properly)
  5. #1525
    Jan 2013
    Homebush, NSW
    Hi guys,
    I might be a bit hopeful here, but when you go to the dealers for a top up / refill the 1L bottle. Do you get charged for it? Surely this should be free? Is there a VW Australia policy somewhere that I can point to?
    I have done less than 1500km and the oil is sitting near the middle of Band C on the dip stick ... sounds like I am might need to have a conversation with the dealer.
    Has anyone else noticed what the colour of your oil is when they wipe it on a white towel? Mine is grey/black after only 1500kms (compared to a clearish/translucent yellow, the natural colour of the oil I assume). Is this normal?
    Thanks guys.
  6. #1526
    Erskineville, NSW
    Quote Originally Posted by skoobysGTI View Post
    The only proper way to do an oil test is to drain the oil & add a measured amount to bring the oil level to the high mark on the dipstick. Do however many km they want you to do - 2000km would make sense. Then drain the oil with the engine at approx the same temp, on the same hoist & let it drain for the same amount of time. Then measure how much came out & compare it to how much went in.
    There should be photos of the dipstick oil level at the start & the finish of the test & the sump plug, oil filler cap & dipstick should all be taped or somehow "stuck" in place to prevent tampering
    Quote Originally Posted by GTI MY13 View Post
    Hi guys,
    Thanks guys.
    Colour is normal.
    Free oil is totally up to the dealer.
    Your engine is still bedding in & it is normal to use some oil in the first 5000km. Just enjoy the car & stop worrying. I'd suggest you drive up a few mountains to aid the bedding-in process
  7. #1527
    I might explain in full.
    Polo GTI 6R
    Engine block replaced at 14,000kms due to piston not lined up, oil leaking and shortly after the something pipe was replaced with a bigger one and less soot comes out the back of exhaust and not as much oil chewed.
    But the oil light keeps coming on and i refill too and WORSE is that...
    My display in the dash goes RED
    OIL Pressure HIGH
    TURN OFF ENGINE
    (with loud beeping)
    Anyone know or experience this? I have my 41500km service soon but I've already done 44289kms to date... (Dealer knows) I've had the car since Jan 2012... New
    [FONT=Franklin Gothic Medium]Matt
    2015 Skoda Octavia RS | Combi | DSG | Metallic Grey | Tech Pack, Every Option Except Leather |
    Prev: 2012 VW Polo GTI | 5dr | DSG | Reflex Silver | RCD510 |
  8. #1528
    Jun 2008
    Ringwood, Victoria
    Sounds like a TPI I read yesterday regarding oil pressure warning coming up. I didn't read the whole thing but it is known about...
  9. #1529
    Italy, Piemonte
    I know that someone will not agree with me, but black oil after only 1.500 Kms is not a good sign...
    Black oil on a gasoline engine means excessive blow-by or something wrong, while is normal on a diesel engine...
    Mine is still clear after more than 10.000Kms and burned 0.5l in 10.000Kms...
    EDIT: here two old pics already posted, taken after the first 6.500Kms (now after oil changing it's even more clear):
    The first taken immediately after dipstick cleaning: http://img834.imageshack.us/img834/6475/15032012881.jpg
    The second after about one day of the same oil diffused on the paper: http://img571.imageshack.us/img571/636/15032012879.jpg
  10. #1530
    Aug 2012
    Brisbane. QLD
    My 12.5 has been in for 2 different hose repalcements.
    After only 1000kms from picking it up from the dealer the low oil warning light has come on and for the first time ever.
    My car has 6900kms on the clock.
    2 attempts at fixing the problem and no help what so ever, but I can believe it burnt that much oil after only 1000 kms
