Just city driving hardly any highway. and the back of the car is just filled with carbon dust, breather hose change didnt change it
Printable View
1500km after my engine rebuild and the oil has not moved on the dip stick. Highly recommend pushing dealers to do engine rebuilds if you are getting high levels of oil consumption. My MY12.5 Polo GTi was using approx 1L/1000km before the engine rebuild.
Hi guys,
I might be a bit hopeful here, but when you go to the dealers for a top up / refill the 1L bottle. Do you get charged for it? Surely this should be free? Is there a VW Australia policy somewhere that I can point to?
I have done less than 1500km and the oil is sitting near the middle of Band C on the dip stick :(... sounds like I am might need to have a conversation with the dealer.
Has anyone else noticed what the colour of your oil is when they wipe it on a white towel? Mine is grey/black after only 1500kms (compared to a clearish/translucent yellow, the natural colour of the oil I assume). Is this normal?
Thanks guys.
The only proper way to do an oil test is to drain the oil & add a measured amount to bring the oil level to the high mark on the dipstick. Do however many km they want you to do - 2000km would make sense. Then drain the oil with the engine at approx the same temp, on the same hoist & let it drain for the same amount of time. Then measure how much came out & compare it to how much went in.
There should be photos of the dipstick oil level at the start & the finish of the test & the sump plug, oil filler cap & dipstick should all be taped or somehow "stuck" in place to prevent tampering
Colour is normal.
Free oil is totally up to the dealer.
Your engine is still bedding in & it is normal to use some oil in the first 5000km. Just enjoy the car & stop worrying. I'd suggest you drive up a few mountains to aid the bedding-in process
I might explain in full.
Polo GTI 6R
Engine block replaced at 14,000kms due to piston not lined up, oil leaking and shortly after the something pipe was replaced with a bigger one and less soot comes out the back of exhaust and not as much oil chewed.
But the oil light keeps coming on and i refill too and WORSE is that...
My display in the dash goes RED
OIL Pressure HIGH
TURN OFF ENGINE
(with loud beeping)
Anyone know or experience this? I have my 41500km service soon but I've already done 44289kms to date... (Dealer knows) I've had the car since Jan 2012... New
Sounds like a TPI I read yesterday regarding oil pressure warning coming up. I didn't read the whole thing but it is known about...
I know that someone will not agree with me, but black oil after only 1.500 Kms is not a good sign...
Black oil on a gasoline engine means excessive blow-by or something wrong, while is normal on a diesel engine...
Mine is still clear after more than 10.000Kms and burned 0.5l in 10.000Kms...
EDIT: here two old pics already posted, taken after the first 6.500Kms (now after oil changing it's even more clear):
The first taken immediately after dipstick cleaning: http://img834.imageshack.us/img834/6475/15032012881.jpg
The second after about one day of the same oil diffused on the paper: http://img571.imageshack.us/img571/636/15032012879.jpg
My 12.5 has been in for 2 different hose repalcements.
After only 1000kms from picking it up from the dealer the low oil warning light has come on and for the first time ever.
My car has 6900kms on the clock.
2 attempts at fixing the problem and no help what so ever, but I can believe it burnt that much oil after only 1000 kms :(
