Page 145 of 226 FirstFirst ... 4595135143144145146147155195 ... LastLast
Results 1,441 to 1,450 of 2252
Thread: Polo GTI High Oil Usage - Discussion Thread
  1. #1441
    Jul 2012
    Guys, if there is enough interest why don't we do our own set of oil consumption testing?
    Instead of going to VW and have them put tape all over the oil cap, we devise our own test.
    People who have a similar driving pattern; i.e. going to work, same route; drive 500kms driving slow, keeping revs down (best leave it in D, or Manual Mode but keeping engine speed below 2k cruising.
    Measure, top up.
    Do another 500kms but going mental, manual mode, drag racing off the lights.
    I'm genuinly interested to see what kind of results we can obtain from CAV, CTHE, and breather modded cars.
    Anyone keen? We'll have a poll, listing ranges of oil consumption and hopefully get an answer if these engines are really true oil chewers - or just affected by the owners drivers style.
  2. #1442
    Jul 2011
    Yeah good idea. It'll be also good to see a range of routes and how it also affects the oil. Some people may have regular short, suburban drives in traffic. Then compare that to someone that drives highway against traffic etc.
  3. #1443
    Dec 2012
    Sutherland Shire, Sydney
    Quote Originally Posted by scobb View Post
    Is that correct? While I'm not saying your technique is equally valid, I always consistently check mine when it is stone cold, typically after it has been stood overnight. Wouldn't this also give an accurate and valid reading?
    The oil expands when it's hot - that's what the dip stick is calibrated for
    This is in my manual, it would be better if they were more explicit...
    One should therefore check the oil level at regular intervals,
    preferably every time after the fuel tank is filled or after driving for long stretches.
  4. #1444
    Erskineville, NSW
    Quote Originally Posted by alexz View Post
    when are you checking the level? it needs to be within 5-10min of turning off the engine (obviously has to be driven for a bit)
    While this is VWs recomended method, using the traditional "check after sitting overnight" method is only going to make a couple of mm difference. The main thing is that the checking method is consistant.
  5. #1445
    Erskineville, NSW
    Quote Originally Posted by gavs View Post
    Don't wait for the bloody light to come on people! You have all read this thread, is it really that hard to pop the bonnet and check your oil when you fill up with petrol? Especially if you don't know exactly how much oil your engine burns?!
    In all honesty, I don't have nay sympthy for those who ocmplain about the light coming on because in reality, if you're already a member on here then you know about the problems. It's just lazyness.
    Couldn't agree more. Can't believe the apathy of some folk.
  6. #1446
    Apr 2013
    Campbelltown
    Apathy? What a load of crap. I've even heard people on here saying that European cars are meant to be checked at every fill up, implying that buying European means taking on extra responsibility. We have owned 3 Mercs, 4 bmws and an alfa, with a range of engines and aspirations and not one required constant surveillance like this, not even the Alfa. As great as the polo is to drive, I can't believe how worried I am about what could happen. Even if it runs perfectly over the next few years, those years are still going to be spent worrying about it. Given that the missus drives it, it is impossible to constantly monitor the oil level, compounded by the fact that where she parks at home is on a hill.
    If people are on these forums worrying about it, it is displaying the absolute opposite of apathy. Stop being so patronising, especially when you are just hitching a piggy back ride on someone else's opinion.
  7. #1447
    Erskineville, NSW
    If a particular engine type has a known reputation for being an oil burner and the owners don't check the oil at all in the first 8,000km & have to add 2 litres of oil (50% of the total fill) then I think there's definately apathy, especially when the owners manual says check the oil every 500km/fuel fill.
    Wouldn't you monitor oil usage until you get an indication as to how much the engine is using & then adjust the preventive maintenance regime to suit? That's industry best practice - write job plan & schedule, check, monitor, adjust job plan & schedule, check, monitor, etc.
    Not being patronising & not piggy-backing. I've expressed my opinion on this issue before & it hasn't changed. Unfortunately, some of you have oil burners. Besides continueing to apply pressure to the dealers & VWA you have to monitor the oil level on an ongoing basis in accordance with the owners manual which recomends every fuel fill.
  8. #1448
    Apr 2012
    Tuggerah, NSW
    Quote Originally Posted by ehsteve View Post
    I wouldn't worry about it ehsteve, i'm not. You know the saying, opinions are like assholes, everyones got one...or is that everyone is one
    Polo GTI 5DR MY13 | Flash Red | Xenons | Leather| Sunroof
  9. #1449
    Aug 2012
    sydney, NSW
    Went to VW at liverpool to do a 15k service + to finalise my oil consumption test. This is the second time round and this time the test shows that it has consumed 600mL/1000km so they are going to do the breather hose replacement (last time it was just under). Fingers cross this will improve the consumption. They also took photoes of the oil/dirt/charcoal that was building up on the back of the car. Shall update everyone if this goes well but who knows if it will. The guy said out of 6 people 1 person had higher oil consumption after the breather hose change. So lets see how this goes.
  10. #1450
    Dec 2012
    Stay in M mode, Keep your revs above 2k rpm and your problem should go away.
