Page 128 of 226 FirstFirst ... 2878118126127128129130138178 ... LastLast
Results 1,271 to 1,280 of 2252
Thread: Polo GTI High Oil Usage - Discussion Thread
  1. #1271
    Erskineville, NSW
    Quote Originally Posted by Diesel_vert View Post
    The temperature readings are within normal operating parameters and does not warrant any further investigation or personal stress/anxiety.
    +1
    you'd think we were discussing old air cooled bugs running on 30 weight mineral oil.
  2. #1272
    Apr 2012
    I'm using VW oil atm so whatever they have put in from the my last breather pipe installation. Castrol I think it is.
    Ok well still I like to keep it close to 100 but mine is generally around 92-98 never really goes over unless i trash it for a good 5-10mins
    GOLF GTI MY11 ADIDAS Candy White, Sunroof
    GOLF GTI 40th ED, White with Sunroof
  3. #1273
    Jan 2009
    Engine oil temperature will depend on engine load.
    If one does not like the idea of the MFD displaying a number higher than 100°C, restricting throttle usage, keeping the engine revs down and reducing speed will ensure of that.
  4. #1274
    Aug 2012
    Geelong, Victoria
    I have seen 105 degrees... pedelling pretty hard. Fabia RS.
    Been told by those that run modified versions that 120/130 is common on a track.
    65ml of oil used for each of the last 2 x 1000ks... after 5500ks (to 7500ks)
    Owner and Operator of 2013 Polo GTI - Sunroof - Xenons - Reflex Silver
    APR Stage 2 Tune - HP Carbon Airbox - Jetex Stainless Cat Back Exhaust - APR I/C
    Plus a few other bits and pieces.
  5. #1275
    Jun 2012
    Christchurch, New Zealand
    Having enjoyed my 1.2TSI Highline for 12 months I'm very seriously considering a trade in to a new GTI (MY2013). This thread and others similar on alternative sites have given me some serious pause for thought. I've got a couple of questions that I hope someone might be able to answer:
    1. I've read somewhere that VW has modified the 1.4 132kW engine to help overcome high oil usage. Does anyone know if this is true, and if so, when the new engines started being fitted to cars? If there is a new engine variant, does the engine have a new code that I could check against to make the car I'm thinking of buying has the new engine?
    2. Slightly different subject: I know the standard (everything but the GTI) 5-door Polo is built in South Africa. I've read somewhere that the GTI is built in Germany. Can anyone confirm this?
    Thanks,
    Simon
  6. #1276
    May 2012
    Quote Originally Posted by scobb View Post
    Thanks,
    Simon
    GTI is built in Spain
    MY16 Candy white Octavia VRS Wagon, sunroof, 19" black pack, tech pack, comfort pack, auto tail gate
    MY12.5 Polo 6R GTI
  7. #1277
    Thanks,
    Simon
    Any MY13 Polo GTI from the factory now will have the updated engine (old engine code: CAVE, new engine code: CTHE)
    I believe the upgrades are the breather pipe fitted at factory, and forged pistons or something. Most people on this forum with the new (CTHE) engine have had much less oil usage than the old (CAVE) engine.
    Alex.
    Alex Aescht
    MY13 Dark Silver VW up! 5-door 55MPI manual — Comfort Style Pack, Comfort Drive Pack, Maps + More, Panoramic Sunroof
    MY11 Pepper Grey VW Polo Comfortline 66TDI manual ― Comfort Pack, Audio Pack.
  8. #1278
    Aug 2012
    Geelong, Victoria
    Quote Originally Posted by alexaescht View Post
    Alex.
    Thanks Alex...I just asked what the difference is in another thread. No need to worry now.
  9. #1279
    Quote Originally Posted by steveyoshi View Post
    That's ok. Happy to help.
    Alex Aescht
  10. #1280
    Jun 2008
    Ringwood, Victoria
    Alex.
    In all fairness there isn't that many CTHE polos on here yet. I think it's too soon to pass judgement in all honesty but the changes do seem to have helped. There is a lot more changes than just a crankcase breather and pistons, the rings are different, a new oil separator and intake pipe work, slightly different cylinder head assembly from memory too. I have outlined all the changes elsewhere on here.
