Page 103 of 226 FirstFirst ... 35393101102103104105113153203 ... LastLast
Results 1,021 to 1,030 of 2252
Thread: Polo GTI High Oil Usage - Discussion Thread
  1. #1021
    Oct 2012
    There is no clip & no heating was required on mine, it's flexible unlike the main plastic line from the engine which is bigger in diameter. I stand by my comments & I have a heat gun, so if necessary would have used it. The middle return simply pulls off, mine pulled off the rubber plug which I then pulled off the manifold. I simply pushed the middle pipe on with the rubber plug inserted (as delivered from VW) when re-installing, takes a small amount of effort - verify it's fully seated by inspection with a flash light.
    It's an easy 10 minute job......
  2. #1022
    Dec 2012
    Athens
    Merry Xmas to ya all and thanks for taking the time fontana.
    As i have guessed it is different in the Cupra. The middle return does not plugs in with the rubber sealing at the end of the middle return, but it actually has a proper quick release safety clip (same as the main return line) with a proper sealing end. Because of this the length of the middle return is too long, and if you try to install without shaping or cutting a small piece of it actually folds out completely.
    I knew i needed pictures for this, which i now got , but turkey comes first.
    Thanks again.
    Custom Stage1+ remap -- Pipercross panel replacement-- S3 322x28 pots-- 9.2 LT FMIC
  3. #1023
    Dec 2012
    Athens
    Quote Originally Posted by RoknRob View Post
    Wow! Less than a litre per 10k? You are so lucky...
    I don't consider myself lucky m8 but i can see where you coming from...
    I also own a VW golf mk5 GT and had virtually no issues with it in 5 years and 60K kms. It uses no oil between 15k changes, and i mean NO oil. BMY euro 4 engine of course.
    I consider the cave/cthe engines a major failure of the group. I consider their chosen path of action (act like nothing happened and deal with its case separately instead of a redesign and recall ) an insult.
    Reliability it is not the group's strong point...
  4. #1024
    New breather hose/pipe fitted a while back, no oil issues and NO black SOOT all over the rear bumper from the exhaust! Just noticed that today! It's a MIRACLE!!!
    [FONT=Franklin Gothic Medium]Matt
    2015 Skoda Octavia RS | Combi | DSG | Metallic Grey | Tech Pack, Every Option Except Leather |
    Prev: 2012 VW Polo GTI | 5dr | DSG | Reflex Silver | RCD510 |
  5. #1025
    Erskineville, NSW
    Quote Originally Posted by Varnak View Post
    BTW i was consuming 950 ml of CAstrol edge every 10K km (which i gues is not bad for the particular engine) . Lets see if that improves with the new breather pipe.
    I know Edge is a different blend in Europe but have you considered another brand? It might just slow the consumption down a bit more.
  6. #1026
    Italy, Piemonte
    Quote Originally Posted by fontana302 View Post
    The same for me, I only had to spray a little amount of silicon oil on the rubber connection to facilitate insertion of the middle return, because of the uneasy position...
    @Varnak, we had almost the same oil consumption (about 1 liter per 10.000Kms), now after pipe replacement mine seems to be halved and main intake pipe (just where the middle return fits into the main) is completely oil-dry...
    Check it before and after the pipe replacement, you should find the same...
  7. #1027
    Dec 2012
    Athens
    It was pretty much the same with Divinol and Valvoline. Do not think it is the oil. My fmic had plenty of dilluted oil in it when i cleaned it up. Will monitor the consumption and decide if the 45 euros spent for the pipe was worth spending
    @kawabanga: it is different on the polo, as i said above. I checked my mates gti. Cupras have a proper quick release mechanism, but they source out the same pipe as a replacement, a bit different installation procedure. I have read your post, which is the reason i bothered buying the new pipe. We ll see if it makes a difference for me as well, as reports from users are contradicting. Thanks anyway neighbour.
  8. #1028
    Italy, Piemonte
    45€?? Here in Italy it's 63€...!!
    Anyway, IMHO it's worth spending: the intercooler will be dry and more efficient...
  9. #1029
    Dec 2012
    Athens
    62.7 here as well minus, dealer discount of 20 something per cent. If i was not on a rush i could have waited for the paperwork and get it on warranty( 5 years). Stealers are not mouthy in this country
  10. #1030
    Jun 2008
    Ringwood, Victoria
    Update on mine, 2000kms of really driving the car enjoyably, 1.5mm drop on the dipstick of Liqui Moly. Compared to Castrol Edge Longlife Professional (half the dipstick) in the same kms with far less spirited driving, proves to me that the Castrol product is rubbish in this engine, only reinforcing the fact is that recently VW released a statement now saying recommended fill is now Fuchs TITAN C3.
    Castrol for me? No f**king way!
