First gear in a Mk5 Golf GTI at 113 km/h is about 12500 RPM, so that person must've pulled the clutch before it got as high as that!
Spot-on. No rev limiter will stop a downshift like that.
'07 Transporter 1.9 TDI
'01 Beetle 2.0
I'd love to know how and why, but as you can imagine, the customer wasn't very forthcoming with information.
'01 Beetle 2.0
This doesn't seem to be the case- read the threads on oil usage sticked on the top. Mine had oil consumption test around 8,000km, engine rebuild (approx 10,000 I think it was) and then engine replacement at 15,000km. I've lost count the amount of litres I've chucked in the car (and the dealer has put in as I go there for top ups after I use my litre bottle of oil) so mine was an excessive case but doesn't seem to be the only one on this forum.
By now the OP had his answer. We have just too many threads with the similar topic. You can continue in this thread; http://www.vwwatercooled.org.au/foru...tml#post819777
