Results 11 to 20 of 25
Thread: POLO GTI Engine Oil Change Question
    Mar 2011
    Clayton South
    [QUOTE=Candy GTI;819366]My car has just under 6000km and this is what it looks like.
    That looks quiet serious.
    Jan 2009
    Don't worry about it at all. Short of dismantling the engine and analysing its components, it's not something you can do anything about.
    You've only just taken possession of your new car - and for all you know, it may not even be affected.
    Start driving already.
    Mar 2011
    Clayton South
    Quote Originally Posted by Diesel_vert View Post
    Yes, I did. Put it on "S" and the car sprints like a rocket. Love that feel! Woohooo.
    I dont even know where to start....
    ah... cant be bothered... plenty of info around the traps here on what to do and what to expect.
    Mar 2011
    Clayton South
    Gambit, we like to hear from you will say.
    Quote Originally Posted by key View Post
    Drive it like you stole it
    Change the oil yourself at 5k km's using recommended oil from VW spare parts and then just monitor therein till 15k km's for its first service.
    Jun 2008
    Ringwood, Victoria
    Quote Originally Posted by Umai Naa!! View Post
    I'd say so.
    How they're pushing this past the warranty office at VW Australia is beyond me.
    I've done probably 15 oil consumption tests in the last 18 months, 5 of which on Polo GTIs.
    The bulletins and procedures state that it should not be performed before the 15,000klm service, and that it is at the customer's expense until proven that the oil consumption is in fact outside the maximum tolerances.
    Believe me, I wouldn't have bothered posting, unless I knew what I was talking about.
    I think that because it is such a widespread, global issue that they get it through. There has been complete engine replacements done in less than 15000 kms in some cases, locally and abroad. I know how you know as I am sure many others do but why else would do many dealerships do it if it's against the instruction of VGA?
    Dec 2008
    Sydney/Canberra
    Quote Originally Posted by gavs View Post
    In the case of the Polo GTI, complete replacement engines aren't usually required. Just a new set of rings, and any other non-reusuable parts, as stated in the workshop manual (ELSA). HOWEVER, as with all engine rebuilds, careful measuring of the bores, pistons, and ring-lands, etc would be required. If the measurements were outside of the specifications, then yeah, a replacement short motor would most likely be the course of action.
    I can't speak for the actions of dealers that have pushed through this particualr field fix before the outlined time period, but I would imagine there'd either be a very good reason for it (With the blessing of VW, no doubt), or some very creative warranty reports. If VW Australia's warranty department decided otherwise, the dealership's claim would most likely be bounced, leaving the dealership to foot the bill. Whether any sort of warranty on that particular repair, or parts used, would be at the discretion of VW Australia.
    It's a messy business, I tell you. This is why I try and encourage everyone to do everything by the book (Til the warranty runs out). Honestly, it doesn't take much for someone at VW to get the big red VOID stamp out.
    I do recall a customer having to supply their own BWA motor for their Golf GTI, after a knocking noise in the engine was complained about. VW requested a data dump of the ECU, which revealed an over rev fault code to the tune of 9,500rpm at 113klm/h. How it didn't throw a leg out of bed truely is a testament to the quality of these engines!
    '07 Transporter 1.9 TDI
    '01 Beetle 2.0
    Jan 2009
    blankedy
    Wow, so how did the ECU allow almost 10k rpm?
    How common are these issues?
    Easy... you down change into 1st gear (manual) whilst doing 113km/h
