Page 3 of 5 FirstFirst 12345 LastLast
Results 21 to 30 of 41
Thread: Polo GTI ECU flash done...
  1. #21
    Feb 2009
    Sydney, Australia
    Takes long, equipment is more expensive, you have to take the ECU out etc. There are no advantages, other than allowing you to flash the ECU when the regular methods don't work. So if it's possible to simply do it via the ODB port, then you'd do it that way
  2. #22
    Quote Originally Posted by way View Post
    Thanks for educating me guys, never heard of bench flashing until this thread. So tell me, is there any disadvantage of bench flashing other than obviously having to take the ECU out?
    Bench flashing only required when the ecu is anti tune like some of the new MED17 ones. It's not really desired or beneficial exactly - OBDII tuning is easier and can utilise remote tuning devices like blue fin, srsII and V-Switch etc...
    bench tuning uses the same mod mapping...
  3. #23
    Oct 2010
    Essendon, Victoria
    ..............also, depending on how it's bench flashed/tuned, you may not get any selectable tuning. That is, new performance tune over writes your stock and you are stuck with it. As far as I know, APR is the only company that can give you this selectability, I hope I am wrong, but I have not read anything to the contrary
    2011 POLO GTI 3dr, Candy White, Audio-Comfort-Xenon Packs
    MODS: H&R Sport Springs - Bilstein B12s - Whiteline Sway Bar - Milltek Cat Back Exhaust - Sparco Assetto Gara Wheels
  4. #24
    Apr 2011
    Eastern suburbs, VIC
    YES!!! APR are having a Winter sale with 15% off ECU tunes.
    I was so bumbed that i missed out on the EOFY sale, but i should have my car next week so i will definitely be taking this up!
    Just unsure whether to go to Volkspower in Burwood or Melbourne Performance Center in Bayswater.
    I work in Bayswater but i've heard MPC aren't the best and haven't really heard much about Volkspower though...
    2011 Polo GTI 5 door Candy White
    H&R Springs/APR Stage 1/OZ Racing Superturismo GT's
  5. #25
    Sep 2010
    Melbourne, Victoria
    It's probably a good idea to drive the car around for a few thousand kms before pursuing an ECU upgrade; if not for the sake of ironing out any potential faults/bugs but so that you can really compare the benefits of the tune.
  6. #26
    Dec 2010
    Quote Originally Posted by DNA Tuning View Post
    I'll be following this advice
    2011 Polo GTI - I have it, I Love It!!!!
    Candy White 5 Door, Comfort Pack, Audio Pack - RCD 510, Bi-Xenons, Panoramic Sunroof
  7. #27
    Cant be bothered going back and reading everything, but can anyone tell me, is the tune just a generic one, or is it dyno tuned to suit each vehicle that gets flashed? ie. will be running a K&N airfilter and wondering whether that can be accommodated to get more power out of it when tuned on a dyno?
  8. #28
    Feb 2009
    Sydney, Australia
    APR, GIAC, REVO, Oettinger, Bluefin, Superchips, Custom Code (all the "brand names") are "off the shelf" tunes. Though, as per many modern cars, the tunes are "adaptable" somewhat by the ECU.
    To be honest with you. Changing your airfilter does zilch. No one has ever "shown" improvements (via dyno etc) on a VAG car from changing the filter. Changing the entire intake is another story...
    The name brand tunes are adaptable enough to account for most intake changes on the Golf's at least. Since there aren't any available intakes for the Polo GTI at this stage, I'm not sure what the situation is.
    You of course can get a custom-written tune on a dyno. Go to a boutique tuner instead of a name brand one.
  9. #29
    Talking
    Quote Originally Posted by Gambit View Post
    On the basis that the car manufacturer puts one 'tune' on a particular ecu for a particular ecu / model - tuners do the same to a large extent. We'll get a model - prepare and test maps for it on the dyno - then launch it for sale as whatever tune it is - Max Eco, blend, Performance, Max Torque, Motorsport, Race Team etc etc.
    So the tune will be whatever you want it to be - certainly in the case of Viezu.
    There is not need to mod a file for small modifications such as and sports filter as the ECU will cope and perfectly adapt 8% on induction and 11% on exhaust. Sometimes when there are a lot of bulk mods then it's an idea to get a bespoke tune but - and I hope I speak for all tuners - we can take account of such things very easily when supplying the map file if required and do so all the time.
    Sports filters have different affects on different cars. Some just get noisier induction roar giving the placebo of speed. Most can give better responsiveness making it feel quicker and you'll see very small gains if you're lucky depending on the vehicle.
    Hope that helps
    Simon
  10. #30
    thats a fair enough response re: airfilter and a generic map and its ability to take into account the variation...
    Just coming from the world of Open ECU tunes, you pay $800~ for a tune thats done on a dyno, bespoke and specific to your vehicle, your able to go into it afterwards to Log and check all tuning parameters with an OBDII port cable and Romraider and take it to another tuner for whatever reason later on if you choose, and get it ECUFlashed again for further fine tuning at whatever hourly rate they charge.
    A case in point with my Subaru, the previous owner had an Ecutek generic map/tune on it, that was locked, in order for another tuner to dyno tune it, i had to get it sent to chiptorque and wipe the ECU and reload an OEM map back on so that i could get it Open sourced tuned. So i have my reservations.
