Results 1 to 5 of 5
Thread: Polo gti 1.8 2017 water pump
    May 2023
    Hey all. My water pump for my 1.8 GTI is leaking unfortunately. How much should I expect to pay for a replacement? I'm located in Melbourne S.E.
    Which brand is best? Genuine or aftermarket
    Any good work shop recommendations? Thanks all
    Nov 2007
    This is a big job I'm afraid. Nose off for easiest access (I have done this personally on 2017 GTI) though I have heard it can be done with the nose still on. Anywhere up from $2500 if you let a workshop do it.
    If you use a workshop, they will generally refuse to use a part given to them by you (warranty of their work reasons), so they will select and choose a replacement part.
    If you do it yourself or with help from a friend, then locally the best price generalle is from VAGPARTS. Can do cheaper from overseas (Europe and even USA) and quite a bit cheaper if you buy from China (still generally OEM quality as it is made for VW China).
    May 2023
    Hi.
    Bought an INNA one.
    Installed it today. Took all day pretty much all day.
    Very tight fit - bumper off is probably the best way like you said.
    The videos online for the 2.0 help but still a little bit different.
    Thanks!
    Not a fun task
    Nov 2007
    Quote Originally Posted by Gerzos View Post
    Hi.
    Bought an INNA one.
    Thanks!
    Not a fun task
    Good outcome! Taking the nose (bumper and radiator cradle) off (cradle swung out of the way without disconnecting AC pipework) is probably a 1-hour job (if you have done it a few times). Saves a massive amount of time and pain getting access to the waterpump.
    This job is already a pain with the nose on, on a MK7, in the Polo it would be nightmare, you did well!
    This was on our 2017 Polo GTI
    Polo gti 1.8 2017 water pump-new-waterpump-fitted-jpg
    May 2023
    Great information. Thank you. So much more room! It was infact indeed a nightmare.. 2 men - blood sweat and tears.. wouldn't recommend this way. Torque wrench just fit..
