Page 28 of 29 FirstFirst ... 1826272829 LastLast
Results 271 to 280 of 285
Thread: Polo aftermarket gear
  1. #271
    AutoBahn
    Quote Originally Posted by MrDeathLad View Post
    If only I hadn't moved on from my Polo...but then again it looks a little "too" aggressive.
  2. #272
    Sep 2012
    Darwin
    Quote Originally Posted by gavs View Post
    Nope, this is the new VAR Design Intake. RRP will be considerably less than the price of the Gruppe M intake.
    The VAR Design intake uses a carbon fibre intake trumpet which houses a specifically designed pod-style filter, manufactured to Viezu and VAR Design's specifications rather than the generic K&N filter used by Gruppe M.
    For further info, contact Simon at Viezu Australia.
    Gavs how is yours mounted to the front, is it secured by a plate or something similar below or above the intake, mine is sitting loose at the moment about 3cm from touching the front
  3. #273
    Aug 2012
    Albury, NSW, Australia
    Quote Originally Posted by Hail22 View Post
    well it is for race purposes... would still run it if i had the money/time etc...
    @mrdeathlad
    #rollinonskittles
    Shorty exhaust, black tails, Kw V1
    Ronal, Oz, Hoshino Racing
  4. #274
    Jun 2008
    Ringwood, Victoria
    It doesn't mount to anything at the front, just the carbon fibre pipe and the plate underneath that fits into a stud next to the fuse panel.
  5. #275
    Apr 2013
    Paddle Shifter Extensions
    Can anyone recommend a particular type/brand of extension paddle shifters? I have seen previous posts in this forum on them but bu...d if I can find them.
    Is this cheap type OK? ie do they fit OK and not come unstuck?
    Steering Wheel DSG Direct Shift Gear Paddle Extension Switch FOR VW Golf Jetta | eBay
    Thank you
    2015 Polo GTI with DA pack : Milltek Turbo back exhaust | DD spacer | JB1 | VWR Turbo Intake elbow and intake hose | BMC panel filter | KW Street Comfort coilovers | Whiteline adjust. endlinks | Harding DSG Perf. tune | Wagner Intercooler| Dotz Mugello 17 x 8 32ET
  6. #276
    Sep 2012
    Darwin
    There what i have and ive had them on for about 2 years plus i live in darwin and they still havent come off so thats a plus with the heat
  7. #277
    Apr 2013
    Quote Originally Posted by sekas View Post
    Good recommendation, thank you Sekas!
  8. #278
    Jun 2013
    Brisbane, Queensland
    Has anyone used these before? Im not having any issues but wanting to go lower....
    MY 13.5 Candy White Polo GTi, with Xenons....
    - Gloss Black roof, Weitec, Whiteline, APR and Harding Performance bits
    - Sound, Mosconi D2 100.4DSP, Mosconi D2 150.2, HAT L6SE Carbon
    List of things to add, custom built subwoofer enclosure by Drivesound
  9. #279
    Aug 2012
    Quote Originally Posted by RUFNIT View Post
    Depends how low you are now. My arch to ground at the front is around 585mm and I'm still all stock in regards to swaybar and associated parts. Haven't noticed and rubbing or knocking.
  10. #280
    Aug 2012
    Polo 6R OEM Bi- Xenon + LED DRL for UK and RHD market
    yeah, they're expensive, but i think they come with everything required (feel free to correct me)... and RHD.
    @mrdeathlad
    #rollinonskittles
