Page 22 of 25 FirstFirst ... 122021222324 ... LastLast
Results 211 to 220 of 246
Thread: Polo After Market page (body kits, light kits, etc) P.S try not to post rice items.
  1. #211
    Nov 2006
    Brisbane Qld
    Absolutely YES. 5 x 100
    PM if you are looking for: R32 rear sway bar; R32 suspension springs; Euro Headlight switches
  2. #212
    Sep 2010
    Quote Originally Posted by graeme86 View Post
    Usually the dealers here fit an "aftermarket" kit sold as the genuine accessory though VW (sourced from Cobra by VW Germany). They can just drill a hole in the bumper and they clip in and look neat. That's why they don't integrate with the car electronics.
    The genuine sensors require a whole new bumper skin which has the sensor mounts molded into the back skin. Then the factory sensors clip in from the back and everything sits flush on the bumper skin.
    If you have the factory sensors they can also be programmed to allow for having a towbar (so the sensors dont go off every time you reverse because they are picking up the towball signal).
    The towbar fitment itself is expensive because it requires a module and special harness as well to integrate all the extra load from the extra tail lights etc into the vehicle electronics. The factory harness would also turn off the rear fog light in the car automatically once you plug it in.
    That price even sounds excessive for VW Australia.
    Graeme86; do you have any ideas where I could get the part number for the proper part your were mentioning? If I can try to get another quote from the dealer.
    Thanks for the information; I knew there would be something available as Billecartz and others who got one of the first 100 had the option, so I can't see why you couldn't buy it as they would need spares for repair and replacement you would think.
  3. #213
    Oct 2010
    miranda
    did you order the adr rear end hail? how much did you end up paying?
    polo 6r tsi dsg sports pack in shiny red.
  4. #214
    Nov 2006
    Brisbane Qld
    Quote Originally Posted by William_Foster View Post
    They list a few different bumpers, with and without towbar option and with and without sensors (and there are also different bumpers depending on licence plate size). You would have to confirm which one fits yours from your VIN/option codes fitted. I believe in the Polos case the bumper for the sensors just has a proper hole pre-drilled. So you might get away with drilling out your bumper carefully with a step drill - there would hopefully be a mark on the inner skin where the holes go. They have to be in the exact location for the mounts to glue on properly as they are shaped to the curve of the bumper skin.
    It looks like the sensor mounts are actually glued to the back possibly as there are some mounting parts listed below for the sensor to mount into.
    So these should be the parts (confirm with dealer).
    4 x Sensors 3C0919275SGRU - require painting
    (4 x O-ring seal 1T0919133C9B9 - may come with sensor anyway)
    1 x bracket - left outer 6R0919491D
    1 x bracket - left inner 6R0919491E
    1 x bracket - right inner 6R0919492E
    1 x bracket - right outer 6R0919492D
    1 x control unit 6R0919475 - will integrate with vehicle electronics properly
    1 x bracket for control unit 6R0971362B - also holds factory trailer module if fitted
    1 x buzzer 8E0919279
    2 x split rivets N0385051 to mount buzzer to bracket
    1 x wiring harness for rear bumper park sensors 6R0971065
    May also require these extra parts to mount module:
    1 x base 867955499
    4 x split rivet N0385051
    Again, you will need to see whats inside your bumper at the moment - especially whether there are any markings in the proper spot.
    I would just order one of the mounting brackets, say - left outer 6R0919491D - just to see what you actually are getting and go from there. If its just a flat adhesive bracket that doesn't clip into something on the inner skin then you would be good to go getting some holes drilled yourself into existing bumper. They have to be pretty exact as well so everything is tight - the sensors are actually slightly tapered where they go through the bumper skin (or at least the O-ring is) so the hole has to be drilled from inside.
    Good luck.
    (This is how I am trying to mount sensors in my R32 - that's why I have researched all this stuff before.)
  5. #215
    AutoBahn
    Quote Originally Posted by matty View Post
    You mean the ABT rear diffuser? the kit is the exact same as the one from the ABT website with the Exhaust centering with Catback, Diffuser (depends on colour or choice you make) with instal priced at $1890 cash
    The negetive side to this is that i have to wait til they bring a shipment in at March (saved a lot of dough) oh well, i at least have the choice to pull out if CCC get back to me with the pricing of the GTI rear bumper as the part i ordered is on back order
  6. #216
    Mar 2010
    Perth, Western Australia
    Quote Originally Posted by bigfoot View Post
    can anyone confirm which H&R springs i need i.e. <929kg or >930kg ?
    28977-1 / 4048419030672
    or
    28977-2 / 4048419031396
    929kg is for petrol cars and 930kg is for diesel cars.
    [/COLOR] 2016 VW Golf GTI MK7 40 Years, DSG, Tornado Red, Tinted Windows,
    2016 VW T6 Multivan Generation Six, Cherry Red with Candy White, VanEssa System with Kitchen, Mattress, Storage Bags, Swivel Seat, Roof Racks with Thule Pod, Dometic Anthracite Awning, Blackout Curtains, Bonnet Bra plus more ..
  7. #217
    Sep 2010
    MELB, VIC
    1 x base 867955499
    Good luck.
    Gday Graeme
    On Our tdi there are markings for where the genuine sensors should mount to the back of the bumper, they are moulded centre marks only (no clip in moulding just markings) when they put our so called genuine kit in they didnt even use these markings I have a photo showing where ours are mounted and the marking below it to the side would like to share this to clarify but dont know how to post photos (any tips?),
    The marking is definately where the guys with the factory fitted sensors have theres mounted, the position is identical to the photos ive seen of the factory mounted kit, (externallay only)
    If anyone gets a quote for this true kit please post it here so noone else gets ripped with the other so called genuine vw cobra kit (ours vw genuine? cobra cost $761 dealer fitted = major rip off, personally think its only worth about $150 max fitted)
    Ps: if anyone has pics of the factory fitted version from behind the bumper could please post them to clarify so we can see how they actually mount them and what they look like.
    Regards
    Mad
    2010, POLO, COMFORTLINE, TDI, DSG, REFLEX SILVER
    2012 MY13 T5 Transporter LWB, 4motion, DSG, Retrofit Rear diff lock
  8. #218
    Sep 2010
    MELB, VIC
    Quote Originally Posted by Billecartz View Post
    I believe it also depends on whether you have a DSG or Manual and which petrol motor you have, (different weights) although the diesel most definatly would require the heavy dutys being a heavier motor,
    Billecartz, If you dont mind me asking which springs did you remove and what did you replace them with? and why? what did you find to be the difference? (hight, compliance, ride, handleing etc)
    Regards
    Mad
  9. #219
    Sep 2010
    Graeme, thanks so much for doing the research and writing that up for us all.
    I will go and see the dealer tomorrow hopefully and see what the story is.
  10. #220
    Sep 2010
    I don't know if this is new on here, but I haven't seen it before; not sure how you could get the kit from Romania but it looks pretty good.
    VW Polo 6R RS Body Kit
