Originally Posted by
kam
i never use auto, because i like to be in control
so everything ive mentioned, has been in manual mode
i tried out a few things today, and found that if i use a temp < 22 deg, it doesnt do it as much
if i put it on 22 with a/c, it does it quite frequently
Yes, because it is designed to maintain the temperature you've set it at, in the most efficient way possible.
Which is why on Auto, the fan will run flat-chat when you first get into the car, so that it gets to your desired temperature.
'07 Transporter 1.9 TDI
'01 Beetle 2.0
