Results 1 to 10 of 11
Thread: Polo 6r wheels
    Dec 2012
    Moe Victoria
    Polo 6r wheels
    Not sure if anyone is able to add to my findings regarding wheel specs for Polo 6r?
    I have a set of 8x18 Audi A8 replica alloys which served me well on a series 4 Golf. They have an offset of 45mm.
    When fitted to my Polo, there are no issues in terms of clearances at the rear. However, there appears to be a problem at the front.
    There is a gap between the strut and the wheel edge of about 10mm, but the wheel actually sticks out about 6mm outside the front guard (illigal?)
    If the offset is changed to 35mm (standard) then this solves the issue of the wheel sticking out past the front guard. Unforunately, at this offset, an 8 inch wheel then collides with the strut.
    Hence, if a standard offset (35mm) is maintained to avoid clearance issues a 7.5 inch wheel is one option. Otherwise an 8 inch wheel would need to have an offset of 40mm whereby a 5mm gap is maintaned betweek wheel and strut, as well as the outside of the wheel being spot on level with the front guard.
    Any thoughts?
    VEEEUU
    Mar 2011
    Netherlands
    ET35 wil bring the rim out 1 cm extra compared to ET45 so you wont have clearance issues, many others have fittes 18x8 ET35 before on a Polo 6R. Can't say anything about the law since I'm on the other side of the world, but I would go for 18x8 myself no problem. Rear can even fit 18x9 if you stretch the tires enough
    Looks like your Audi wheels are et35 or 32 as standard polo gti wheels are et46 and they sit in about 10-15mm from the front guards. My 18x8 et35 wheels sit around 5mm proud at the front, 18x9 with an et38 fit fine in the rear
    Dec 2012
    Moe Victoria
    Thank you for respondong with this information.
    I am not keen to have the wheels sticking out beyond the front guards. Since there is about 10mm clearance between wheel and strut on an 18x8 with an et36 then if the et was increase to 40mm, the rim would come in towards the strut 5mm and not protrude past the guard. A clearence of about 5mmm would still be maintaned between the wheel and strut. (Hope I am right?)
    Are you aware of any alloy wheels in Australia where a customer can nominate the et?
    Kind regards
    VEEEUU
    Also, I intend to
    Quote Originally Posted by BLN355 View Post
    Im sure you could get the wheels you have milled down to fit better?
    shaving a few mm off the mounting face will bring them in
    Dec 2012
    Moe Victoria
    Are you able to give me the make of your wheels and where did you buy them? (perhaps a picture?)
    Kind regards
    VEEEUU
    Dec 2012
    Moe Victoria
    Hello Dave
    Thank you for your rsponse.
    Not sure if lowering the front (35/55 H&R springs) will actually create some negative camber and hence pull the top of the wheel in closer?
    Hence, the wheel may not stick out past the guard. Only need about 5 to 8 mm.
    Kind regards
    VEEEUU
    May 2012
    northern rivers
    URGENT can anyone tell me if detroit rims off a MK5 Golf???? 7.5x17 ET 51 will fit my 2010 polo GTI 6R?? THANKS
    Mar 2011
    Quote Originally Posted by jivebug View Post
    Why did you double post this?
    Quote Originally Posted by VEEEUU View Post
    Any thoughts?
    VEEEUU
    going from 8et45 to 8et35 will not bring the wheel in closer to the guard? will push it out futher
    keep in mind offset is based on width, think you might be leaving some info about hte wheels out?
    Bora gone
    Vento VR6
    MKIV GSW TDI
    7P Touareg TDI
