Page 5 of 9 FirstFirst ... 34567 ... LastLast
Results 41 to 50 of 88
Thread: Polo 6R Tyre Advice
  1. #41
    AutoBahn
    Quote Originally Posted by iigx View Post
    Might do the same. Anyone here running the Adrenalin Re002's on the PGTI and got any comments over stock ? Reading the info on Tyre Reviews they appear alot better than the Dunlops.
    Bridgestone Adrenalin RE002 | the Bridgestone Adrenalin RE002 reviewed and rated | the online tyre guide
    Dunlop SP Sport Maxx | the Dunlop SP Sport Maxx reviewed and rated | the online tyre guide
    Either mid May or Early June Dunlop will cease production of the Dunlop Sport Maxx range, so far the RE-002 has great grip if the pressure and tyre temps are moderate what I like is the tread life I think the tread count is 300-320?
  2. #42
    Jun 2008
    Ringwood, Victoria
    I'm tossing up beween federal 595 rs-r or the RE002. The RE002 by all reports is a phenominally good tyre, especially in the wet considering the tread patterns on the tyres. So, my choices now are RE002, Dirrezza z2 or RS-R.... Leaning toward RE002 because as Hail pointed out, the tread wear is meant to be bloody good for an ultra performance tyre. I've gotten 40,000kms out of my Sport Maxx's so if I can get that out of the RE002 then that would be great.
  3. #43
    AutoBahn
    4x RE002 for $690 Balanced and fitted at Bridgestone Select Gladesville om nom nom nom nom <3
  4. #44
    Jun 2008
    Ringwood, Victoria
    Polo 6R Tyre Advice
    Wah?!?! What size for that coin?! 105/10/R12?!
  5. #45
    AutoBahn
    I just got it knocked down further upon payment $675 cash money
    215/40r17 87W
    got a free wheel alignment chucked in after my wheels were covered in tyre grease! (which is gone now as I just washed them).
    that equates to $167.3 per tyre
    Bit of bait for you guys to nibble on before you decide to jump on this incredible deal!
  6. #46
    Mar 2011
    You sure you got an alignment?
  7. #47
    AutoBahn
    Quote Originally Posted by ATYPIC View Post
    Obviously only the toe can be adjusted...which it was...it was pulling slightly to the right and now it seems better now.
  8. #48
    Sep 2011
    I've got 17" RSRs on my other car which is RWD and about 100kgs heavier than the Polo. Dry grip is phenomenal for a street tyre and very predictable at the limit, but with a treadwear rating of 100 you'd likely get 15000ks max out of a set. Surprisingly the noise level isn't much higher than something like Sport Maxxs. Wet grip is not great but driving normally for wet conditions you should not have any problems.
    RSRs pick up a lot of gravel and throw it into the inner guards and most sizes also look a bit chunky on the rim when compared to most other tyres which some may not like.
    For an all rounder I think RE002 is looking pretty good, I wouldn't go the RSRs and if I was going to track it I would get proper R types.
    MY11.5 6R GTI 3 DOOR
  9. #49
    Apr 2008
    Bridgestone also do the Potenza S001 in 215/40/17 87Y. Has anyone tried this tyre on the PGTI?
    Gone: Aug 2013 Build MY14 Polo GTI | Candy White | RNS510 | Panoramic Sunroof | Bi-Xenons | Rear Parking Sensors
    Current: Late March 2015 Build Mk7 Golf GTI Performance Pack | Pure White
  10. #50
    Sep 2012
    NSW
    I am still running my stock Bridgestone RE050, but I was wondering, when you guys took your car in for service, did they do a tyre rotation? I can see the sheet they provided me showed the tread left on each tyre, but didn't mention a rotation.
    The sheet showed the fronts are more 'used' than the rears by 3-5mm.
