Page 2 of 2 FirstFirst 12
Results 11 to 20 of 20
Thread: Polo 6R track requirements
    Sep 2012
    NSW
    Quote Originally Posted by Melon Head View Post
    Give me a break , only had the car for 5 days, and haven't hit the track in 16 years.
    Seriously call the Alfa Romeo car club and ask to speak to someone about track days. Best bunch of guys that can help you.
    Seems sacriligious mentioning the Alfa car club here but they take their club racing seriously.
    Hehe, you must be having a blast with your car, I was until all the dramas began!
    Lets see if my oil consumption has settled and I will head out for some track action. I'm not too keen to go with a club as it will mean a packed track. I like heading there with a small group of 3-4 cars and go on a weekday to avoid the rush.
    On a side note, I don't think a set of track tyres is necessary. I did 3-4 track days with daily driving in my Integra on Bridgestone RE001's and they were still going strong. The only thing to be scared of is the tyres going stale due to the heat cycles. With my polo coming eith RE050s I think it should be OK.
    Sep 2012
    I agree with Gavs below, semi-comp tyres, track pads & intercooler are a must unless you only want to do three laps at a time.
    I would even toy with the idea of going down an inch in rims if you were to buy a new set specifically for track days, the skinny low profile 17" might be hard to find semi-comp track tyres for, fatter 16" semi's might be more readily available & provide better grip, less under steer.
    As for other generic things required for scrutineering(?):
    -Blue Battery triangle, buy a kit off ebay & get it delivered (should come with tow hook stickers which generally not required). Cheaper than buying it on the day & atleast you will have spares if you dont plan on leaving them on between track days.
    -Fire extinguisher, make sure its less than 3 years old and has two mounting bolts dia. 6mm or larger. Approved Extinguishers costs $20 from bunnings, PM me for pic of bracket I made up before a Motorkhana late last year, can be easily bolted/unbolted under passenger seat and doesn't require any holes drilled into car.
    -Some clubs may require you to have metal valve caps, most don't.
    -You might have to screw in your tow hook located next to your spare wheel into the front bumper (small removable plastic panel under RHS headlight I think).
    I'm not sure if the Gti has one as standard but look into fitting or upgrading an oil cooler with thermostat, I saw temps of over 110deg. c after only repeated short minute long 'blats' on a 35deg day at lower speed on a skid pan & short TT circuit. I would imagine a 7 lap session on a track day would produce higher temps, but may be kept in check with higher speed airflow through car.
    Some might be, but I'm not comfortable with sustained 120+ deg oil temps, use your MFD as gauge to know when to back off. I'd much prefer to go this route rather than changing engine oil after every track day, oil shouldn't break down if you keep the temp low.
    If you're precious about your paintwork maybe look into some clear 3M film on the front of your car & behind front wheels & down low on your rear bar. These areas tend to get trashed if your running with semi comps that get hot & stick to everything, releasing them on the straight, also from cars in front with semi's throwing up rocks into your path.
    Quote Originally Posted by gavs View Post
    While not critical, i'd look at the following:
    Intercooler. not so much an issue for one or two days but with the heatsoak that will aflict you on the track with this motor, you really should look into this. It will also help in keeping the intake temps down on highways etc as well. Mine drops heatsoak temps very quickly now, to the tune of about 5-10 secs at 60kph after 20 mins @ 100kph. It used to take 25-30 secs in the same circumstances.
    Tyres. oh man you need tyres. Look at some cheap semi slicks to start with because you will hate having to replace your normal every-day tyres all the time. One track day will probably destroy the Dunloip SP Sport Maxx'.
    Trans oil, don't bother. it's a sealed, lifetime fill.
    If you go to full track-spec pads, do a proper bed-in otherwise i'd be stocking up on rotors
    Dec 2012
    Melbourne, VIC
    Yeah love the car. Just waiting to see how the car goes over the next 6 months to see if I will start spending money on it for the track
    I got the RE050 tyres on my car too.
    Nice tyres.
    I have RE002 on the Swift, also good.
    Dec 2012
    Melbourne, VIC
    One thing I would definitely fix is the brakes.
    I don't like the spongey feeling of them - not confidence inspiring at all.
    Maybe better brake lines might improve
    Aug 2011
    Turning up the brake assit helps. I've just been to a 30min happy laps event (and def plan to go more) and the high setting helps.
    Setting the traction to strong also worked well, it never cut in. It's the same setting the 'rocco R carries. I also hit 110deg about half way in (35deg day).
    VCDS For 6R Polo (primarily GTI)
    Dec 2012
    Melbourne, VIC
    Thanks
    Just downloaded the software
    Dec 2012
    Melbourne, VIC
    Is this the right cable?
    VAG Diagnostics Ltd - VCDS Vag-Com 908, 912, & 10.6 Cables - About
    Where does it connect to the car?
    Aug 2011
    Those are pirate copies and they don't work well with 2011+ cars, the genuine one is a Ross Tech Hex+Can. The cheaper Micro-CAN won't work
    Theres lots of people, especially in melb, which have cables who can help out too
    Dec 2012
    Melbourne, VIC
    OK. Thanks
    Mar 2011
    Wollongong
    Club VW supersprint at Wakefield Park is on May 25th. I'm just putting together the permit paperwork for it now.
    Wollongong Sporting Car Club's Huntley Hillclimb at Dapto next weekend 3rd February. Entry forms etc available from www.wscc.org.au\download.shtml now. If you are 21 or under its there's free entry and membership for this.
    Minimum standards for these 2 events you will need:
    - a Level 2 Speed Licence - just a matter of filling out the form and parting with cash.
    - membership of a CAMS affiliated car club (any of them, you can search for one on CAMS website under development > clubzone.
    - 900g fire extinguisher fitted to the car removable by the driver without tools. Apart from screwing it directly to the floor/tunnel/a pillar, usually you make a bracket with aluminium plate that bolts in with the seat mounts and attach the fire extinguisher to it. When you buy a fire extinguisher look at the date. They are only allowed to be 3 years old. They may be approaching that on the shelf.
    - battery triangle, just make a triangle with blue electrical tape.
    - numbers on both sides. Make them with tape, white boot polish, print them on paper and stick them to the inside of the windows.
    - taped headlight glass for the sprint.
    - AS1509( think it is ) helmet.
    - Non synthetic clothing from neck to wrists to ankles. Cotton socks, leather shoes.
    At huntley you wont need anything special in brakes. You'll only use them once on the track. At Wakefield they will get hot. They will probably start to fade by the end of your 4 flying laps but they wont go to the floor. There are 3 hard brakes but they are spaced out.
    Its a bizarre rule but if you do races you actually dont need a fire extinguisher at all.
