sorcam, this is most likely the common issue (as mine was) of a dodgy batch of noise generators. After being fixed, no longer an issue. THe oil issue, well you should be taking this up with the dealership, simple as that. No point complaining here to be honest with you.
I love mine. Yeah, i had a few rattles and even not being an oil drinker, it still drinks some but hey, the engine is designed to do that, its the trade off for fuel economy and it's actually worse insummer due to higher temps etc and cooling down the engine from the inside.
Honestly, show me another car that issues aside can match the polo gti for the same coin, the same level of fit and finish, cabin ambience and performance and i'll run around nicky nude with a placard advertising it. It just can't be done.
I had a panic just before picking mine up after reading about the issues, but when performance tuners seem to be able to sort alot out with just a few strokes of the keyboard AND make the car even more potent, just shows that the VW engineering department leve a lot to be desired
Get it is all I can say
I'm off for a fang in mine now, see if I can show that blue RS200 Clio around here a few more tricks through warrandyte
