That's bloody impressive but I imagine most of that weight saving is in the calipers (machined aircraft aluminum billett vs gravity cast T356 or similar aluminum) so it's non-rotating mass. It would be interesting to know the rotational moments of inertia of the rotors (anyone else remember the effect of the big brake upgrade on the Top Gear Renualt Aventine's lap time? OK, they had to 'upgrade' the wheels to fit over the bigger brakes which also hurt the time but this is another thing people do here a lot)
That's the point - an old Falcadore is quite likely to be underbraked but Polo GTis and the like are very well spec'd in this manner and pads and fluid are limiting on road factors (unless maybe towing but who hoons while towing a trailer??).
Braking really, really late on every corner going down a mountain just isn't smart - if you only do it every now and then because you are being caught out, the brakes will recover (and you need to adjust your braking points).
All you are saying is quite pertinent but I think you are simplifying things unnecessarily - I'd rather you give the full blown tech picture with justification for why the things you are saying are the best choices instead of dumbing it down
