Apart from the normal "take it to a dealer" what you described sounds a bit like the switch is the issue.
hi guys
my boot light stopped working properly long time ago, it started with a long delay before it turned on and now its completely stop working.
can anyone point me out the problems?
cheers
Mine does exactly the same thing, with a delay between opening the boot and the light turning on.
Have you noticed a change in the sound/behaviour of the boot release mechanism by any chance?
Alex Aescht
MY13 Dark Silver VW up! 5-door 55MPI manual — Comfort Style Pack, Comfort Drive Pack, Maps + More, Panoramic Sunroof
MY11 Pepper Grey VW Polo Comfortline 66TDI manual ― Comfort Pack, Audio Pack.
have you actually checked the bulb? if the bulb is ok its more than likely the boot latch micro switch playing up. when you open the boot does it display the door open symbol on the dash panel?? ....VDUB....
VOLKSWAGEN TECHNICIAN - 16 YEARS OF PAIN..VCDS CODING- FAULT DIAGNOSIS - PRE PURCHASE INSPECTIONS- REPAIRS9W2 BT KITS -$300 - 9W7 BT KITS - $450 - CANBUS UPGRADE $150BRISBANE / GOLD COAST
It will be an open circuit some where in the boot, best to take it to stealership. Had the same problem with mine
MY11 Polo Trendline, Candy white
RCD510, R badge, AP X coilovers, 17" Ariettas in gloss black, Rear muffler delete, GTI pedal covers, gloss back emblems
soon to come, Front lip & Fat bottom steering wheel
Alex Aescht
then it will need a new boot latch if the wiring is ok which it 99%of the time is.... not a hard job....VDUB...
my boot light comes on the dash
bulb ok? holder ok? connection plugged in?.....
