Results 1 to 10 of 20
Thread: Polo 6R Boot Light issue
    hi guys
    my boot light stopped working properly long time ago, it started with a long delay before it turned on and now its completely stop working.
    can anyone point me out the problems?
    cheers
    Jul 2012
    Apart from the normal "take it to a dealer" what you described sounds a bit like the switch is the issue.
    Mine does exactly the same thing, with a delay between opening the boot and the light turning on.
    Have you noticed a change in the sound/behaviour of the boot release mechanism by any chance?
    Alex Aescht
    MY13 Dark Silver VW up! 5-door 55MPI manual — Comfort Style Pack, Comfort Drive Pack, Maps + More, Panoramic Sunroof
    MY11 Pepper Grey VW Polo Comfortline 66TDI manual ― Comfort Pack, Audio Pack.
    Mar 2013
    Brisbane QLD
    have you actually checked the bulb? if the bulb is ok its more than likely the boot latch micro switch playing up. when you open the boot does it display the door open symbol on the dash panel?? ....VDUB....
    VOLKSWAGEN TECHNICIAN - 16 YEARS OF PAIN..
    VCDS CODING- FAULT DIAGNOSIS - PRE PURCHASE INSPECTIONS- REPAIRS
    9W2 BT KITS -$300 - 9W7 BT KITS - $450 - CANBUS UPGRADE $150
    BRISBANE / GOLD COAST
    Jul 2012
    Coogee, NSW
    It will be an open circuit some where in the boot, best to take it to stealership. Had the same problem with mine
    MY11 Polo Trendline, Candy white
    RCD510, R badge, AP X coilovers, 17" Ariettas in gloss black, Rear muffler delete, GTI pedal covers, gloss back emblems
    soon to come, Front lip & Fat bottom steering wheel
    Quote Originally Posted by vdubmotorworx View Post
    In mine, the bulb is fine and no open door/boot light comes on the dash.
    Alex Aescht
    Mar 2013
    Brisbane QLD
    then it will need a new boot latch if the wiring is ok which it 99%of the time is.... not a hard job....VDUB...
    Ok thanks
    Alex Aescht
    my boot light comes on the dash
    Mar 2013
    Brisbane QLD
    bulb ok? holder ok? connection plugged in?.....
