Page 2 of 2 FirstFirst 12
Results 11 to 20 of 20
Thread: Polo 6R Boot Light issue
    everything appears ok, the bulb, holder and plug.
    Mar 2013
    Brisbane QLD
    Quote Originally Posted by sun_corp View Post
    Have you actually got 12v at the plug?,
    VOLKSWAGEN TECHNICIAN - 16 YEARS OF PAIN..
    VCDS CODING- FAULT DIAGNOSIS - PRE PURCHASE INSPECTIONS- REPAIRS
    9W2 BT KITS -$300 - 9W7 BT KITS - $450 - CANBUS UPGRADE $150
    BRISBANE / GOLD COAST
    I just had a closer look at mine and the bulb and holder are fine, but there is no voltage at the plug at all, except occasionally when it decides to work.
    So I think it's a switch or something that's failed.
    Alex Aescht
    MY13 Dark Silver VW up! 5-door 55MPI manual — Comfort Style Pack, Comfort Drive Pack, Maps + More, Panoramic Sunroof
    MY11 Pepper Grey VW Polo Comfortline 66TDI manual ― Comfort Pack, Audio Pack.
    Mar 2013
    Brisbane QLD
    sometimes the rear washer jet leaks into the boot latch and micro switch and causes issues... press and hold rear washer jet on for 10 seconds then open the tailgate and see if any water comes from the latch area from around the interior trim..
    Quote Originally Posted by vdubmotorworx View Post
    Thanks I'll try that later and report back.
    Would putting the car through a touch less car wash maybe get water in places it shouldn't be?
    Alex Aescht
    Mar 2013
    Brisbane QLD
    possible... but ive only ever seen the rear washer leak causing that issue....
    Ok just a thought.
    Alex Aescht
    Apr 2024
    Melbourne, Victoria
    Question Hi from 2024
    Quote Originally Posted by alexaescht View Post
    Hi Alexa, did you ever solve this problem and get the boot light working? If so how? I have the same issue on my polo gti. Hopefully you still see this message considering how long its been. Cheers
    @Polo gti 6r: Hi.
    I'm also not sure if Alex is still around !! However, with the hope that I'm not stealing his thunder - this is my very cut-down version of how the "boot light" is wired (I'm assuming that your car is a hatch version):
    If you are not familiar with VW's wiring notation - notice T5h /2 on my diagram. This means:
    • T5 = is a connector with a Total of 5 x pin positions
    • h = a simple designation that identifies this 5 x pin connector from multiple other 5 x pin connectors on the car
    • /2 = pin #2 on the connector
    So, the story that the wiring diagram tells - is:
    1. The supply for the boot-lid light (W3) comes from J519 (which is the module for lots of "convenience" facilities on the car). Notice that there is NO circuit fuse - J519 auto protects this circiut
    2. The same power supply for W3 also feeds W6
    Because you haven't said that the glove compartment light (W6) is also faulty - the fault is probably NOT in the J519 wire
    There are 4 x connections that could cause W3 to be faulty:
    1. T2 = the connectors for the boot light
    2. T5c
    3. T5h
    4. T3 = the connections in the boot lid switch, or the switch in F5, itself
    According to the Polo repair manual, it's NOT possible to renew the switch in F5 without replacing the entire boot- lid mechanism.
    So, my suggestion = grab a multi-meter and start checking the connectors above!!
    Pacific Paradise QLD
    You can buy a whole new Boot release on EBAY for about $30 and is identical to a factory part Difference is about $100 and fixed a similar problem in our Polo . You can also buy a new LED light on Ali Express for under $20 which gives much more light
    For VW Golf MK5 MK6 Rear Tailgate Trunk Boot Lock Latch Lid Actuator Brand New | eBay
