Polo 6R backing Light - How do I get two?
Can anyone tell me why the good Burghers at VW decided to install only one reversing light in the 6R? I understand that the same decision also was made in the mk6 Golf. I'm sure that this issue has been raised before - but do Europeans have better eyesight than us Aussies, or are they just better at judging distances in the dark? It can't be about cost cutting- I wouldn't have thought that the marginal cost of an additional backing light and associated wiring would be all that much. In fact, when I look at the RH rear tail-light assembly (from the outside), it seems that the backing light lens is actually already part of the unit. What a strange thing to do (IMO).
But enough about complaining-my real purpose in writing this post is to enquire about how to work-around this curious decision. I've already installed an LED replacement in the LH tailgate assembly and this simple fix did significantly improve the illumination at the rear of the car. There are lots of alternative LEDs, but the reason that I chose my LED was because it appeared to have a good forward projection lens and a high efficiency LED, plus it had a CANBUS error facility which actually works. But, I had to buy 2 LED lamps because all other cars (except the 6R) have two backing lights. This is what the LED replacement looks-like for those that are interested:
I now have a remaining LED which I would like to install into the RH side tail-light assembly (where it seems that VW have included a matching backing light lens, but no backing light). I haven't yet removed the RH taillight assembly- can anyone tell me how much "infrastructure" is provided for a 2nd backing light. Is there any wiring in the RH tail light assembly for a 2nd backing light, or will I have to run a switch wire to the LH side of the car (presumably across the boot floor pan-somewhere)? If a new wire is required, is it OK to use the "earth" from the RH tail light, or does the Polo "smarts" require separate earths for the LH and RH tail lights? Finally, does the RH tail light assembly have a BA15S socket base to take a 2nd backing light, and if not, how have others managed to hold the 2nd backing light in place?
Thank you in advance for responding
