Results 1 to 10 of 14
Thread: Polo 6R 77 TSI DSG - MFD Menu for Digital Oil Temp Display.
    Dec 2010
    Albany, WA
    Hi, I think this is the right place for this - The manual of my new Polo 77 STI DSG (page 23/24) says the 'Multi Function Display' can show "Digital Oil Temperture Display". Page 22 says to open the menu, "Switch on ignition" then "If a message or vehicle pictogram is being dispayed, press the OK button"..... The operative word here is "IF" because mine doesn't. The dealer service manager couldn't help. Does anyone know how to get into the menu and select items to display. Besides getting oil temperature I'd like to unselect 'Speed Warning' as it's never going to get used!
    Feb 2010
    Quote Originally Posted by Phil_Polo77TSI View Post
    When I sat in the Polo GTI, it had the advanced version of the MFD (including a Vehicle Pictogram). I know that My Polo has the basic version which doesn't have a menu, and doesn't display temperature. I'm sure your's would be the same.
    2020 VW Golf R
    Dec 2010
    Albany, WA
    Thanks Allegiance - I was hoping there is a crack or workaround for this - engine/oil temp is pretty basic....
    Feb 2010
    Yeah I know, lack of oil temp sucks donkey balls.
    2020 VW Golf R
    Frewville, South Australia
    Would buying a VCDS (Vagcom) cable allow you to change what is displaying - I am hoping because I want some to do some changes. Intend buying one when my Golf GTI arrives to keep the Polo company.
    Mark 7.5 2018 White Golf R with Driver Assist & Dynaudio packages.
    Polo 77TSI White Comfortline DSG - partner drives
    We are a VW family
    Feb 2010
    Don't think so, it's a basic MFD, not that advanced version in the GTI etc.
    2020 VW Golf R
    Dec 2010
    Albany, WA
    Quote Originally Posted by GTi Crow View Post
    Thanks GTi Crow, now that I have found out what a "VCDS (Vagcom)" is, your post makes a lot of sense. Not something I'd buy and try myself and probably not something your friendly VW Dealer would do for you, but I wonder if there are independant VW specialists out there who apparently use these things can do, or have done this. Can't be rocket science if you know what you are doing...
    Nov 2006
    Brisbane Qld
    If you don't have the pictogram in your dash then you may need to buy a whole new Highline cluster which wiill have the oil temp capability programmed into it. You have to have the correct cluster as per the manual page in the first post.
    PM if you are looking for: R32 rear sway bar; R32 suspension springs; Euro Headlight switches
    Dec 2010
    Albany, WA
    Thanks Graeme86, It seems there is no chance with my Polo's MFD type. Any suggestions for an 'add on' gauge? Analogue or digital?
    Sep 2010
    Quote Originally Posted by graeme86 View Post
    Graeme, that the second time I have heard reference to the Highline Cluster; do you know what models this comes on? Hopefully the TDI, or is it just the GTI?
    6R Polo TDI; DSG
