Results 11 to 20 of 31
Thread: P3 Gauge
    May 2012
    Im have spoke to P3 a dozon times and they always come back with "where going to Europe next month and will look at the polo there"
    Been getting the same response all year. Still nothing out.
    MY16 Candy white Octavia VRS Wagon, sunroof, 19" black pack, tech pack, comfort pack, auto tail gate
    MY12.5 Polo 6R GTI
    Mar 2008
    Sunshine Coast
    Quote Originally Posted by lunchboxGTI View Post
    I've personally seen two Polos where the owners mounted the P3 screen in the vent. It's just held in with an aluminium mounting bracket.
    Jun 2008
    Ringwood, Victoria
    P3 Gauge
    Quote Originally Posted by Candyman View Post
    I think he was referring to a few that had bought the ultra gauge and found it wouldn't display boost
    It does look a bit crap too
    I have mine to display the following:
    Boost
    Coolant temp
    Intake temp
    Cat temp
    Output torque
    Actual RPM
    Oxygen sensor voltage
    Timing advance (intake)
    Sep 2012
    Darwin
    Quote Originally Posted by gavs View Post
    Boost
    Coolant temp
    Intake temp
    Cat temp
    Output torque
    Actual RPM
    Any chance you have photos of your set up gavs?
    Mar 2008
    Sunshine Coast
    Boost
    Coolant temp
    Intake temp
    Cat temp
    Output torque
    Actual RPM
    Boost on our R showed as 39 psi with the ultragauge
    analog sensor with P3 was on the money.
    I just dont trust the UG (and it looks ****e)
    Jul 2011
    Umm I don't doubt what you saw but I read in the manual somwhere that it only displays boost at +/- 13 PSI (or somthing like that so I'm not sure how you got 39. Sure it wasn't displaying boost in KPA?
    Also as I have said it reads OBDII data so its not like it makes the stuff up. It reads what the ECU puts out and from what a can see with VCDS using the OBD read mode - both data is the exact same.
    Jun 2008
    Ringwood, Victoria
    P3 Gauge
    There are 2 different boost settings, one which is higher than it actually is, the other which is the accurate one.
    Irrespective of looks, I bought it for a function and for my purpose it works just fine, even though I am generally more style driven than many other people
    Jul 2012
    Mulgrave, Victoria
    Not sure if this has been covered before but for gauges I use the ELM 327 OBD-II reader (eBay $10-$20) and the Torque app on the Samsung S4 - looks good and response times are very acceptable. Very cheap but effective solution.
    May 2012
    Has anyone got the fiscon basic-plus from kufatec? Says its compatable but would be hessatent to try it first. And I don't need the bluetooth.
    It says its red screen only but shows a picture of it on white MDF.
    FISCON Bluetooth Handsfree - "Basic-Plus" - VW, Skoda-36496_M
    MY12.5 Polo 6R GTI
    Jul 2011
    ^that looks really cool. Shame I only have the basic MFD which has a pre set LCD
