ultra gauge ordered.. just received my tracking number should be here on Monday
As far as I know, the E-MFA add on doesn't work due to the OBD/CANBUS setup on the polo.
Yeh no worries I will give you guys a review when I get it early next week
Got the ultra gauge and it seems to be pretty good.. Value for money if you ask me heaps of gauges to chose from
Gav what gauge do you use for boost? I'm using the boost pressure psi gauge does anyone know what boost the cars are meant to run in a gti? My car seems to vary from 16 pound to 20 pound and I can't seem to find anything to be sure
Anything out there other than VCDS displays EGT?
EGT? If you mean exhaust temp then yeah UltraGauge should do something close to it as you can read the O2 sensors pre and after the cat. I would assume you could pull temp data from the sensor.
