Results 1 to 10 of 14
Thread: Out of warranty gearbox issues
    Hello,
    I have a 2012 Polo Gti. Lately I have noticed a shudder taking off in 1st gear manual mode. Seems to be more noticeable when the engine is warm. Don't seem to notice as much in D mode. I read a lot of horror stories on the gearbox in these cars. Honestly wished I hadn't bought one. The car has only done 25000km. So first question, what may be causing this? Second question, has anyone had their gearbox fixed outside the warranty period done at VW's expense (as a good will gesture)? I did have the extended warranty but that has expired about 4 mths ago. Surely these gearboxes are made to last more than 25000km!
    Jan 2013
    Brisbane, QLD.
    Quote Originally Posted by Speshboy View Post
    Hello,
    You need to replace cluthces. Visit dealer for a EKG test @ your cost then get them to apply for goodwill. Or just go straight to a specialist. Goodluck.
    Any idea how much it would cost to replace the clutch?
    Sunshine coast
    Not sure if it's the same cost on a Polo, but my Passat B7 DSG will get a new clutchpack from VW under warranty. The cost outside warranty would be $1350 parts and $924 labor. This is dealership cost, I'm sure that through an independent it would be quite a bit less.
    132TSI Tiguan Allspace
    Jan 2013
    Brisbane, QLD.
    I used to R+R clutches in 1.4 hours flat including re-shimming. But book time is 6 hours + parts.
    Jan 2014
    Queensland
    if you do replace it consider this as a long term solution DSG7/DQ200 Clutch Pack with Kevlar discs (MY2012+) - Clutches - Products
    Thanks for the heads up. So I'm assuming these will last longer than the standard clutch. Gez costs a bit though. The shudder doesn't happen all the time though. Not sure why that is. Seems more when the car is warmed up.
    Jun 2007
    Did you take it to a dealer yet? At 25,000KM, there's a good chance it will cost you nothing.
    George
    06 Jetta 2.0TFSI Killed by a Lexus!
    09 Eos 2.0TSI DSG Loved this car but has now gone to a new home!!
    14 EOS 2.0 TSI has arrived!
    Apr 2013
    Quote Originally Posted by SloAu View Post
    I was doing some research recently on after market clutch packs, just in case! I noted that listing above but a few things did not look right so I went through Rexbo International GMbH (DE) and they advised me that Luk do not do a Kevlar disc clutch pack for the DQ200.
    Anyway I have sent an email to the company TMG Performance and asked them to confirm the listing above as correct? Meanwhile beware.
    2015 Polo GTI with DA pack : Milltek Turbo back exhaust | DD spacer | JB1 | VWR Turbo Intake elbow and intake hose | BMC panel filter | KW Street Comfort coilovers | Whiteline adjust. endlinks | Harding DSG Perf. tune | Wagner Intercooler| Dotz Mugello 17 x 8 32ET
    Oct 2015
    UK
    Quote Originally Posted by car_nut View Post
    Yes, LUK do not do a clutch pack with Kevlar disks - that clutch pack is a modified LUK pack by TMG performance, they take a normal LUK clutch pack and replace the clutch plates with custom Kevlar friction plates. This is why it's so expensive, a normal LUK clutch pack for the DQ200 is around 350 euros.
    TMG performance is a high end tuning and parts manufacturer in Greece - they do a lot of custom kit for the 1.4 TSI that no one else does, primarily because the 1.4 TSI is very popular in Greece (tax reasons on small capacity engines).
