If your engine stops when you are sitting in neutral without braking it wouldnt start again would it. But it does when you take your foot off the brake so perhaps its brake related.
Think about it do you just roll to a stop without braking and it stops or do you brake to a stop in neutral and then hold it on the brake.
Would love to Ray, but unfortunately I bought this and told the wife I wouldn't do anything to it
That being said I would love to add a tune to it and maybe some wheels and coilovers too, but I don't think that I can get away with the visual appearance without the wife noticing haha.
I will have to try it on the way home from work this afternoon, I am not too fussed with the start stop I don't mind it, you just need to time it at lights when you want to take off is all. Let me know when you get VAGCOM, I wouldn't mind doing the odd tweak here and there ( as long as it is free then the wife is still smiling)![]()
Hey,
Good timing, I just took the car out to the shop and checked it. Definitely switches engine off even when there is no brake.
I first discovered this in peak hour traffic in Melbourne, as long as it's in neutral and clutch is out it'll turn off. Might just be my car *Shrug*
EDIT - answer to question: I need clutch to start my car, Engine stop doesn't function when engine is cold, aircon is on and cabin temp is too high etc. it also doesn't function straight off, you have to have been moving and once you tap the clutch it often won't cut the engine again until you've either engaged a gear and removed it or if you've actually moved.
There is a VCDS tweak you can do to permanently disable it. It would be the 1st thing on my list to do .....
Congrates mate... Novated lease takes money pre tax but not all right? Just a small amount rest after tax
Yeah tested the stop-start today; should say that mine is DSG. Occurs only when I step on the brakes with a bit of pressure when I've stopped (cruise to a stop with a slight hold on the brake doesn't trigger it). Doesn't enable when the cabin fan speed is set at 3+ and A/C is on too.
Yep correct!
