Under warranty or not? I would still recommend using an approved oil. It's your engine the oil protects not the dealer's.
If the oil usage is an issue, choose the oil which the second number is higher, instead xW30 use xW40 or even xW50 (if you find one).
On the oil's specs sheet, look for the oil with the higher Flash Point, it will be more resistant to burning.
