Page 2 of 2 FirstFirst 12
Results 11 to 18 of 18
Thread: Oil Overfill HELP!!!
    Apr 2011
    sydney
    I got a proper jack...how hard is it to drain it a little myself?
    I noticed they charged me for a new sump plug..
    Potts Point, New South Wales
    Don't even worry about it....trust me.....i work on 51.7 litre V12 caterpillars and MTU's and gas turbines....your lil TSI will be fine!
    AutoBahn
    Quote Originally Posted by Acko1991 View Post
    Remind me when you see my Polo "R" to not let you hold a torque wrench...
    You think a little bit of oil is bad......you should see some of the stuff that happens in aviation. Nothing to worry about seriously....There is always lee way for things like that...If you had too much oil u would be blowing loads of black smoke before ure catalytic converter blew.
    Jun 2011
    anstead qld
    Quote Originally Posted by marcs View Post
    guys i went in there today and spoke to a head mechanic, he said they do purposely overfill them however he said mine was overfilled by 3mm. He said that it wont do any damage. He said that these cars have a high oil to fuel consumption. He said I wont need a top up obviously. Whats the purpose of the manual then seriously!!!
    I've noticed mine has been overfilled before after going in for a driveway service.
    2011 Polo GTI black, audio, comfort pack, xenons, leather, alarm, sunroof, bluetooth. Picked up!!!!
    Jun 2008
    Ringwood, Victoria
    interesting, the service manual from VW says that they shouldn't touch the sump plug, they should vacuum it out with sump plug removal a last resort.....
    It's not hard to drain at all, the hardest bit is removing the underpan. The REALLY hard bit will be draining the right amount
    Just use WOT for a bit, that will burn some off if you're really worried about it...
    Jan 2009
    Bit of a band-aid "solution" if you ask me, unless there's a TSB instructing the dealer to do that.
    Why not just fill it up to MAX as normal and just give the customer a 1 l bottle of oil to put in the boot.
    Jun 2008
    Ringwood, Victoria
    I'm with you mate, though I wouldn't say band-aid solution, I'd say a bulltish solution, but i'm a pessimist when it comes to service departments
    Overfill the car, say it's normal which contradicts everything the manual says about oil level, tell the customer it's fine in regards to the catalytic converter which again, contradicts the manual....
