Page 71 of 76 FirstFirst ... 21616970717273 ... LastLast
Results 701 to 710 of 756
Thread: The official 6R Polo visual appreciation thread
  1. #701
    Apr 2013
    My car is 6C. Just over 2kg off each corner is probably correct when I measured on our digital bathroom scales. I also got around 1.6 kg per corner on a digital suitcase scale but that reading is likely wrong, it varies if the thing being weighed is not held very steady. Wrote the figures down but can't find them.
    New wheels are 8.25" and the detroits are a heavier looking wheel than the 6Cs.
    2015 Polo GTI with DA pack : Milltek Turbo back exhaust | DD spacer | JB1 | VWR Turbo Intake elbow and intake hose | BMC panel filter | KW Street Comfort coilovers | Whiteline adjust. endlinks | Harding DSG Perf. tune | Wagner Intercooler| Dotz Mugello 17 x 8 32ET
  2. #702
    May 2014
    WA
    Yep all makes sense now.
    The damn Detroits weighed heaps!
    Full APR Stage 2
    HP APR Exhaust | HP APR CAI | HP APR Intercooler | APR Tune
  3. #703
    Apr 2013
    Quote Originally Posted by spare View Post
    I just weighed a 6C wheel and I make it 10.3kg which further confirms all the above.
  4. #704
    Nov 2013
    Missed out on the flat 5000 Yesterday, This is the Closest i Could get.
    Attached Thumbnails Attached Thumbnails The official 6R Polo visual appreciation thread-polo-dash-jpg
  5. #705
    Quote Originally Posted by charais93 View Post
    It was Optus' fault. Should've reminded you to stop at 4999.9kms.....
    MY13 Kluger KX-S AWD / MY16 Polo GTI
    MK6 MY10 Golf GTI, 5dr Manual, Carbon Steel, Detroits, Tint
    T6 MY06 Peugeot 307 HDi Touring, Manual, Iron Grey, Tint
  6. #706
    Sep 2010
    The tacho redline is different from my 81 TSI. The thicker part of the red starts at 6500rpm with it. The above pic looks a bit more like the redline mark on our Golf 90 TSI. The 81 TSI marking makes more sense as in both cars the rev cutout is 6500rpm.
    Nov '15 Polo 81TSI manual white
  7. #707
    Jun 2015
    WA
    Quote Originally Posted by car_nut View Post
    Thanks mate. Offset is actually 38. They are not XXR527s, rather Hustler XR 17 x 8.25, identical apart from the extra offset which Wheelworx told me is achieved by shaving the hub surface of the wheel.
    Went for these wheels after considering much more expensive options, like you could not find anything with a good 'dish' look in required offsets. Had them on nearly 2 months and no problems at all. Fronts are ideal offset if you don't want rubbing, backs you could certainly go to 35 or use 10mm spacers maybe? 35mm offset at front and you will definitely get rubbing.
    Seems like my current wheels didn't work out due to front brake clearance which I didn't account for so now I am back to the same wheel as you which I plan to order this week. Looks like they have them in gloss black now so I am going to get that finish as I have painted all the trim on mine gloss black.
    Question, do you have after market suspension and how much space do you have between back of wheel and strut on those? Mate runs 8" +35 on the front with no issues but these are 8.25 and apparently I only have around "a finger" at most on the stock detroits. Was just worried about the wider rim and the backspace but it's possible that the extra width of the rim is in front of the hub, not the rear and will be fine. If you are running +38 without any hit then I guess anything with below that is going to clear fine?
  8. #708
    Jun 2015
    WA
    New wheels on today and NO RUBBING and I've pushed it hard over my high speed test dips - VERY HAPPY
    Just need to drop it a bit at the front.
    Excellent job by Wheelworx
    Hey dude, also did you get the black wheel lugs from wheelworx and extended or normal size? I just realized I am going to need to swap mine or it's going to look awful.
  9. #709
    Apr 2013
    Quote Originally Posted by Swattysin View Post
    I do have KW coilovers but I reckon the physical external dimensions of the strut assembly will be the same as standard.
    You are right the back of the front wheel is horribly close to this strut assembly, can't get my hand in through the wheel past the brake discs to feel and car is too low to get under it, maybe a finger. Back wheel clearance is almost 2 fingers. Photos are of front.
    Forum member 'Raphii' has XXR530s fitted which are 8.25s with 35 offset with Eibach springs I think, think he has no clearance issues - you could message him.
    I am fairly confident you will be OK with the same wheels as me on std struts etc or coilovers.
    Attached Thumbnails Attached Thumbnails The official 6R Polo visual appreciation thread-p1030981-jpg   The official 6R Polo visual appreciation thread-p1030980-jpg
  10. #710
    Apr 2013
    Yep you definitely need new wheel lugs, they should be supplied with the wheels. By the way I reckon the std Hustler caps look terrible and I can give you some tips on making up your own from plastic 'blanks' - message me with your email address if you are interested.
