They should be from factory, if not there is a chance you car has had the interior lights set to a different region.
Hi, so I was reading through some other forums about the Polo and discovered that in Europe (where it is a legality to have Daytime Running Lights 'DRLs') the Polo uses its parkers on the front only as them (VWVortex.com - Polo 6R DRL help - halogen type). I found also that the feature is not software related, but hardwired so I pulled out the light switch in the car and looked at the pins but the pin for the DRLs (labeled 'TFL') was actually there, and a wire was connected and running back into the dash.
So basically I was wondering if and how the DRLs could be turned on.
Thanks for any help!
Alex Aescht
MY13 Dark Silver VW up! 5-door 55MPI manual — Comfort Style Pack, Comfort Drive Pack, Maps + More, Panoramic Sunroof
MY11 Pepper Grey VW Polo Comfortline 66TDI manual ― Comfort Pack, Audio Pack.
Exterior, do you mean? If so that would make sense, but I was just wondering. So nothing the dealer can do, or is it not possible?
Edit: Sorry, just re-read your post. So the car should already have the DRLs on from the factory? I've never noticed another Polo in Victoria with them on, but I haven't really paid much attention.
Alex Aescht
The lights might be external but the control switch is part of the central electrics on the interior so the coding is for the interior. I could go into greater detail but without it sounding overly complex, there are different country/region settings and these setting have their defaults. Your car might be set to a different region.
Yes, they should be set to on from the factory.
