Originally Posted by
gavs
Ok, first off I will answer a few of the more basic questions you have posed.
Some say that I need to replace the steering control unit for a GTI model?
For a start, yes. This control unit is it's own little ECU for the steering wheel functions including the paddles and the steeringwheel buttons for stereo and MFD.
Some say the Polo doesn't have this unit?
Then how do the steeringwheel mounted buttons work seeing as there is no direct wiring connection? What else controls the cruise / indicators / wipers etc?
Most likely it needs to be activated in VCDS, wich I have access too so not a problem there..
I'm thinking, if it can be done on a GTI it can be done on any Polo DSG right?
Yes, it does need to be re-coded through VCDS and yes, theoretically you are correct. How in depth is it though? Well.....
I know of a tutorial for the retro-fit of the GTI MFSW onto a non MFSW equipped TSI but aside from the whole pulling apart looms, splicing of wires, buying new loom connections and a whole new wheel also, there is no guarantee at this stage that it can be done on a non GTI and 100% work properley. While I am sure that the gearbox codes differ due to the bellhousing and clutch pack etc, I cannot be 100% sure that those are the only differences. There may also be something different in the mechatronics but I have no idea, I doubt it but you never know.
So, the definative answer to your question, Can I fit paddle shifters to my 77TSI with DSG?
No.
Can I retro fit a whole new GTI steering wheel with everything incorporated, along with new looms and splicing of wires and pulling half of your dashboard apart to do it so you can get to the wiring for the LIN bus and then re-code the whole thing with VCDS and hope to god you got all your wire connections right and didn't fry anything in the process?
Yes.
